1. Re: list component to txt file
kglad Oct 21, 2013 4:50 AM (in response to vari25)you can't save movieclips in a text file. do you want to save their names in a text file?
2. Re: list component to txt file
vari25 Oct 21, 2013 5:02 AM (in response to kglad)exactly..Yes!!!!
Or feeding data automatically into a excel sheet.
Please advise.
Thank You.
3. Re: list component to txt file
kglad Oct 21, 2013 7:23 AM (in response to vari25)use the urlloader class to save those names to your server-side script.
4. Re: list component to txt file
vari25 Oct 21, 2013 9:53 PM (in response to kglad)Thank You.
Pardon for my ignorance in this.
But how to set up the flash file i.e., Movieclips should be defined in a variable or ...?
submit.addEventListener(MouseEvent.CLICK, sendData); function sendData(event:MouseEvent):void { var urlreq:URLRequest = new URLRequest ("http://www.mydomain.com/file.asp"); urlreq.method = URLRequestMethod.POST; var urlvars:URLVariables = new URLVariables(); urlvars.uname = nametxt.text; urlvars.apellido = aptxt.text; urlvars.email = emtxt.text; urlvars.cedula = cctxt.text; urlvars.score = scoretxt.text; urlreq.data = urlvars; var loader:URLLoader = new URLLoader (urlreq); loader.addEventListener(Event.COMPLETE, completed); loader.dataFormat = URLLoaderDataFormat.VARIABLES; loader.load(urlreq); } function completed (event:Event):void { var variables:URLVariables = new URLVariables( event.target.data ); resptxt.text = variables.done; }How to get this work in my flash file.
I have a portfolio to submit, Please help.
Any help would be apprecaited.
Thank you in advance.
5. Re: list component to txt file
kglad Oct 21, 2013 10:33 PM (in response to vari25)use:
//use a local path
var urlreq:URLRequest = new URLRequest ("/file.asp"); urlreq.method = URLRequestMethod.POST; var urlvars:URLVariables = new URLVariables();
var visableNum:int=0;
for(var i:int=0;i<arr.length;i++){
if(arr[i].visible){
urlvars["visible_mc"+visableNum++]=arr[i].name;
urlvars.uname = nametxt.text; urlvars.apellido = aptxt.text; urlvars.email = emtxt.text; urlvars.cedula = cctxt.text; urlvars.score = scoretxt.text; urlreq.data = urlvars; var loader:URLLoader = new URLLoader (urlreq); loader.addEventListener(Event.COMPLETE, completed); loader.dataFormat = URLLoaderDataFormat.VARIABLES; loader.load(urlreq); } function completed (event:Event):void { var variables:URLVariables = new URLVariables( event.target.data ); resptxt.text = variables.done; } -
6. Re: list component to txt file
vari25 Oct 22, 2013 2:42 AM (in response to kglad)Thank You.
The below urlvars r not required?
As this script was suggested by some friend, I have no idea.
So the above code:
//use a local path
var mcNameA:Array=["square_mc","circle_mc","rect_mc"];
for(var i:int=0;i<mcNameA.length;i++){
if(this[mcNameA[i].visible){
urlvars["visible_mc"+visableNum++]=mcNameA[i];
Then the asp server side script will call the movieclips names to a database file, right?
And another doubt, If I have multiple movieclips visible on stage, then all the mc's visible would be feeded to that asp file right?
Thank You in advance.
The script above is what required to send the visible movieclips on stage to a asp file?
Or anything else is to be added?
Kindly advise.
Thank You.
7. Re: list component to txt file
kglad Oct 22, 2013 7:22 AM (in response to vari25)urlvariables (or some other object) is required to assign a data property to your urlrequest and is used in the code i showed to send data to your asp file. if your asp file looks for POST'ed variable/value pairs and writes the values to a text file, then all should work.
in the code i suggested, i'm sending the variables, visible_mc0, visible_mc1, .. etc with values = the names of the visible movieclips listed in arr. you copied the code i first posted. i later amended that code a few minutes later to use your arr array.
here it is the code without the extraneous lines:
//use a local path
if(arr[i].visible){
urlvars["visible_mc"+visableNum++]=arr[i].name; // <- this is where i use your urlvariables to assign variables/values
urlreq.data = urlvars; //<- data property assign to your urlrequest
resptxt.text = event.target.data;
8. Re: list component to txt file
vari25 Oct 22, 2013 9:00 PM (in response to kglad)Thank You so much for the kind reply.
9. Re: list component to txt file
kglad Oct 23, 2013 2:35 AM (in response to vari25)you're welcome.
10. Re: list component to txt file
vari25 Oct 23, 2013 3:12 AM (in response to vari25)Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL: file:///file.asp
at output_txt_ex1_fla::MainTimeline/sendData()
This is an error FLash throwing
What to do?
Please help
11. Re: list component to txt file
kglad Oct 23, 2013 8:58 AM (in response to vari25)you should test that on your file server that supports asp.
if you're running an asp server locally, you have an incorrect path to file.asp.
12. Re: list component to txt file
vari25 Oct 24, 2013 4:43 AM (in response to kglad)Thank u .
I would check that.
13. Re: list component to txt file
kglad Oct 24, 2013 5:57 AM (in response to vari25)you're welcome.
