I've inserted a web object in to my project and filled it with text so that it requires scrolling. The project has been published as HTML5 with no scalable HTML content.
Scrolling works fine on PC but not on iPad (iOS 7). I'm guessing that this is down to the usual iFrame issues on iOS devices so I'm looking for a reliable way to get around this issue.
I'd be grateful if anyone has any suggestions.
As an aside, the main reason I'm looking to implement a web object is that I need to be able to style individual words within large amounts of text. Unfortunately this doesn't seem possible using the scrollable text interaction so I've had to resort to searching for an alternative solution, in this case pulling in an external HTML file with styled text in it. The full discussion is here for anyone who's interested: http://forums.adobe.com/message/5775245#5775245
Thanks.
Hi - I am having the same problem, which i am hoping is fixed ASAP.
Does your Web Interaction show "Updated" on it? If not, you probably have older version of it. Apparently, the issue is already fixed in the updated version. Here is a screenshot.
You get this updated version automatically. If not, you can contact any Adobe support staff and they will provide you one.
Sreekanth
Thanks for letting me know and I my version does not say "updated"
I will contact Adobe support.
Thanks again
where you have find the "updated" info?
I am searching for view similar the screenshot posted by Sreekanth_S but unsuccesfully.
You can probably write to the Adobe staff for the updated widget. Here are couple of IDs you can try your luck with:
Nimmy nsukumar@adobe.com
Haridoss ramadoss@adobe.com
Sreekanth
