This content has been marked as final.
Show 6 replies
1. Re: Frame rate problem with music
Szalam Oct 21, 2013 10:34 AM (in response to jayman2567)1 person found this helpfulAs long as both items are interpreted correctly in After Effects' project panel, they should both be able to sit together in a 30 fps comp without any need to stretch anything.
2. Re: Frame rate problem with music
jayman2567 Oct 21, 2013 11:30 AM (in response to Szalam)What do you mean by interpreted correctly?
3. Re: Frame rate problem with music
Szalam Oct 21, 2013 11:47 AM (in response to jayman2567)If you right-click on the footage item and click on interpet footage>main and ensure that the frame rates are correct (30 and 28), they should play back correctly in the 30 comp.
4. Re: Frame rate problem with music
jayman2567 Oct 21, 2013 11:57 AM (in response to Szalam)hmmmmm this might work lol....imma render it right now and see what happens! Thanks man XD
5. Re: Frame rate problem with music
jayman2567 Oct 21, 2013 12:21 PM (in response to jayman2567)Can I render the whole composition as 28 frames and still have my footage at 30????
6. Re: Frame rate problem with music
Todd_KoprivaOct 21, 2013 12:35 PM (in response to jayman2567)
Yes.
