10 Replies Latest reply: Dec 12, 2013 7:27 AM by Nick Spiropoulos RSS
    MP4 (h.264) changes in CC from CS6
    Nick Spiropoulos Community Member
      I'm creating an update to a film to be played on a Brightsign Roku XD1030. The original film was encoded by CS6. The new update was encoded with CC using the same settings. The XD1030 player has problems starting playback with the files created in CC. WinPCs and Macs play the MP4s flawlessly from both CS6 and CC, but on the Brighsign the CC encoded file plays audio for a second, then picture cuts on a second late, then a moment with only picture, then both audio and picture play the remainder of the file fine. This required me to go back to CS6 to encode, which worked perfectly.
      The source file is 1920 x 1080 x 29.97, ProRes 444 Stereo audio.
      What is different between the MP4 (h.264) encoders in AME?
      Creative Cloud Settings:
      Creative Suite 6 Settings:
        • 1. Re: MP4 (h.264) changes in CC from CS6
          thnord Adobe Employee
          Could you please load both files in to MediaInfo (http://sourceforge.net/projects/mediainfo/) and post a screenshot of the results?
          Thanks.
          • 2. Re: MP4 (h.264) changes in CC from CS6
            Let me know if you want "complete" data from Media Info...
            Good File From CS6 AME
            CC AME encoded file with Brightsign problems
            • 3. Re: MP4 (h.264) changes in CC from CS6
              Go ahead and send the full report. The only thing that jumps out at me is the CC version mentions a "nominal bitrate", but the CS6 version doesn't. It seems unlikely that it is the problem though.
              Does this happen with all files created using these settings in CC?
              I'll try to track down a Roku. Could you please provide me with the firmware version of the one you are using?
              • 4. Re: MP4 (h.264) changes in CC from CS6
                There are three files (acts) to this museum exhibit (the 2nd act will be updated yearly). Files 1 and 2 do not have the problem, only file 3. Yet, all three files are created using exactly the same process. The 2 files are are okay using CC are running fine onsite.  I'm including the MediaInfo for only the problem file.
                Here's the "complete" readout:
                CS6 File (Good)
                General
                Count                                    : 287
                Count of stream of this kind             : 1
                Kind of stream                           : General
                Stream identifier                        : 0
                Inform                                   : MPEG-4 (Base Media / Version 2): 140 MiB, 49s 716ms
                Count of video streams                   : 1
                Count of audio streams                   : 1
                Video_Format_List                        : AVC
                Video_Format_WithHint_List               : AVC
                Codecs Video                             : AVC
                Video_Language_List                      : English
                Audio_Format_List                        : AAC
                Audio_Format_WithHint_List               : AAC
                Audio codecs                             : AAC LC
                Audio_Language_List                      : English
                Complete name                            : /Volumes/Little League 5/-Exports 5/AV06 Dugout/10-10-13/AV06_Dugout-Theater_D_FILM ACT 3 wCaps CS6.mp4
                Folder name                              : /Volumes/Little League 5/-Exports 5/AV06 Dugout/10-10-13
                File name                                : AV06_Dugout-Theater_D_FILM ACT 3 wCaps CS6
                File extension                           : mp4
                Format                                   : MPEG-4
                Format                                   : MPEG-4
                Format/Extensions usually used           : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
                Commercial name                          : MPEG-4
                Format profile                           : Base Media / Version 2
                Internet media type                      : video/mp4
                Codec ID                                 : mp42
                Codec ID/Url                             : http://www.apple.com/quicktime/download/standalone.html
                Codec                                    : MPEG-4
                Codec                                    : MPEG-4
                Codec/Extensions usually used            : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
                File size                                : 146772910
                File size                                : 140 MiB
                File size                                : 140 MiB
                File size                                : 140 MiB
                File size                                : 140 MiB
                File size                                : 140.0 MiB
                Duration                                 : 49716
                Duration                                 : 49s 716ms
                Duration                                 : 00:00:49.716
                Overall bit rate mode                    : VBR
                Overall bit rate mode                    : Variable
                Overall bit rate                         : 23617815
                Overall bit rate                         : 23.6 Mbps
                Stream size                              : 54768
                Stream size                              : 53.5 KiB (0%)
                Stream size                              : 53 KiB
                Stream size                              : 53.48 KiB
                Proportion of this stream                : 0.00037
                HeaderSize                               : 53237
                DataSize                                 : 146719673
                FooterSize                               : 0
                IsStreamable                             : Yes
                Encoded date                             : UTC 2013-10-17 20:37:23
                Tagged date                              : UTC 2013-10-17 20:37:23
                File last modification date              : UTC 2013-10-17 20:37:31
                File last modification date (local)      : 2013-10-17 16:37:31
                ©TIM                                     : 01;00;00;00
                ©TSC                                     : 30000
                ©TSZ                                     : 1001
                Video
                Count                                    : 264
                Kind of stream                           : Video
                StreamOrder                              : 0
                Inform                                   : English, 24.0 Mbps, 1920*1080 (16:9), at 29.970 fps, AVC (NTSC) (Main@L4.1) (CABAC / 3 Ref Frames)
                Format                                   : AVC
                Format/Info                              : Advanced Video Codec
                Format/Url                               : http://developers.videolan.org/x264.html
                Commercial name                          : AVC
                Format profile                           : Main@L4.1
                Format settings                          : CABAC / 3 Ref Frames
                Format settings, CABAC                   : Yes
                Format settings, ReFrames                : 3
                Format settings, ReFrames                : 3 frames
                Internet media type                      : video/H264
                Codec ID                                 : avc1
                Codec ID/Info                            : Advanced Video Coding
                Codec                                    : AVC
                Codec                                    : AVC
                Codec/Family                             : AVC
                Codec/Info                               : Advanced Video Codec
                Codec/Url                                : http://developers.videolan.org/x264.html
                Codec/CC                                 : avc1
                Codec profile                            : Main@L4.1
                Codec settings                           : CABAC / 3 Ref Frames
                Codec settings, CABAC                    : Yes
                Codec_Settings_RefFrames                 : 3
                Duration                                 : 49716
                Source duration                          : 49716
                Source duration                          : 49s 716ms
                Source duration                          : 00:00:49.716
                Bit rate mode                            : CBR
                Bit rate mode                            : Constant
                Bit rate                                 : 24000000
                Bit rate                                 : 24.0 Mbps
                Width                                    : 1920
                Width                                    : 1 920 pixels
                Height                                   : 1080
                Height                                   : 1 080 pixels
                Pixel aspect ratio                       : 1.000
                Display aspect ratio                     : 1.778
                Display aspect ratio                     : 16:9
                Rotation                                 : 0.000
                Frame rate mode                          : VFR
                Frame rate mode                          : Variable
                Frame rate                               : 29.970
                Frame rate                               : 29.970 fps
                Minimum frame rate                       : 29.970
                Minimum frame rate                       : 29.970 fps
                Maximum frame rate                       : 30.000
                Maximum frame rate                       : 30.000 fps
                Frame count                              : 1490
                Source frame count                       : 1490
                Standard                                 : NTSC
                Resolution                               : 8
                Resolution                               : 8 bits
                Colorimetry                              : 4:2:0
                Color space                              : YUV
                Chroma subsampling                       : 4:2:0
                Bit depth                                : 8
                Bit depth                                : 8 bits
                Scan type                                : Progressive
                Interlacement                            : PPF
                Interlacement                            : Progressive
                Bits/(Pixel*Frame)                       : 0.386
                Delay                                    : 0
                Delay                                    : 00:00:00.000
                Delay, origin                            : Container
                Stream size                              : 145541492
                Stream size                              : 139 MiB (99%)
                Stream size                              : 138.8 MiB
                Proportion of this stream                : 0.99161
                Source stream size                       : 145541492
                Source stream size                       : 139 MiB (99%)
                Source stream size                       : 138.8 MiB
                Source_StreamSize_Proportion             : 0.99161
                Language                                 : en
                Language                                 : English
                Language                                 : English
                Language                                 : en
                Language                                 : eng
                Language                                 : en
                Buffer size                              : 16799744 / 16799744
                mdhd_Duration                            : 49716
                Audio
                Count                                    : 221
                Kind of stream                           : Audio
                StreamOrder                              : 1
                Inform                                   : English, 192 Kbps, 48.0 KHz, 2 channels, AAC (LC)
                Format                                   : AAC
                Format/Info                              : Advanced Audio Codec
                Commercial name                          : AAC
                Format profile                           : LC
                Codec ID                                 : 40
                Codec                                    : AAC LC
                Codec                                    : AAC LC
                Codec/Family                             : AAC
                Codec/CC                                 : 40
                Duration                                 : 49716
                Source duration                          : 49771
                Source duration                          : 49s 771ms
                Source duration                          : 00:00:49.771
                Bit rate mode                            : VBR
                Bit rate mode                            : Variable
                Bit rate                                 : 192000
                Bit rate                                 : 192 Kbps
                Maximum bit rate                         : 280125
                Maximum bit rate                         : 280 Kbps
                Channel(s)                               : 2
                Channel(s)                               : 2 channels
                Channel positions                        : Front: L R
                Channel positions                        : 2/0/0
                Sampling rate                            : 48000
                Sampling rate                            : 48.0 KHz
                Samples count                            : 2386368
                Frame count                              : 2330
                Source frame count                       : 2333
                Compression mode                         : Lossy
                Delay                                    : 0
                Delay relative to video                  : 0
                Video0 delay                             : 0
                Stream size                              : 1176650
                Stream size                              : 1.12 MiB (1%)
                Stream size                              : 1 MiB
                Stream size                              : 1.1 MiB
                Stream size                              : 1.122 MiB
                Proportion of this stream                : 0.00802
                Source stream size                       : 1178165
                Source stream size                       : 1.12 MiB (1%)
                Source stream size                       : 1 MiB
                Source stream size                       : 1.1 MiB
                Source stream size                       : 1.124 MiB
                Source_StreamSize_Proportion             : 0.00803
                Language                                 : en
                Language                                 : English
                Language                                 : English
                Language                                 : en
                Language                                 : eng
                Language                                 : en
                mdhd_Duration                            : 49771
                CC File (Problematic)
                General
                Count                                    : 287
                Codecs Video                             : AVC
                Complete name                            : /Volumes/Little League 5/-Exports 5/AV06 Dugout/10-10-13/AV06_Dugout-Theater_D_FILM ACT 3 wCaps CC.mp4
                File name                                : AV06_Dugout-Theater_D_FILM ACT 3 wCaps CC
                Format                                   : MPEG-4
                Format                                   : MPEG-4
                Codec ID                                 : mp42
                Codec                                    : MPEG-4
                Codec                                    : MPEG-4
                File size                                : 136868693
                File size                                : 131 MiB
                File size                                : 131 MiB
                File size                                : 131 MiB
                File size                                : 131 MiB
                File size                                : 130.5 MiB
                Duration                                 : 49716
                Overall bit rate                         : 22024088
                Overall bit rate                         : 22.0 Mbps
                Stream size                              : 54641
                Stream size                              : 53.4 KiB (0%)
                Stream size                              : 53.36 KiB
                Proportion of this stream                : 0.00040
                HeaderSize                               : 53110
                DataSize                                 : 136815583
                FooterSize                               : 0
                IsStreamable                             : Yes
                Encoded date                             : UTC 2013-10-16 18:44:13
                Tagged date                              : UTC 2013-10-16 18:44:13
                File last modification date              : UTC 2013-10-16 18:44:24
                File last modification date (local)      : 2013-10-16 14:44:24
                ©TIM                                     : 01;00;00;00
                ©TSC                                     : 30000
                ©TSZ                                     : 1001
                Video
                Count                                    : 263
                StreamOrder                              : 0
                Format                                   : AVC
                Codec ID                                 : avc1
                Codec                                    : AVC
                Codec                                    : AVC
                Codec/Family                             : AVC
                Codec/CC                                 : avc1
                Duration                                 : 49716
                Bit rate mode                            : CBR
                Bit rate                                 : 21825788
                Bit rate                                 : 21.8 Mbps
                Nominal bit rate                         : 24000000
                Nominal bit rate                         : 24.0 Mbps
                Width                                    : 1920
                Height                                   : 1080
                Rotation                                 : 0.000
                Frame rate mode                          : CFR
                Frame rate mode                          : Constant
                Frame rate                               : 29.970
                Frame count                              : 1490
                Standard                                 : NTSC
                Resolution                               : 8
                Resolution                               : 8 bits
                Colorimetry                              : 4:2:0
                Color space                              : YUV
                Bit depth                                : 8
                Bit depth                                : 8 bits
                Interlacement                            : PPF
                Bits/(Pixel*Frame)                       : 0.351
                Delay                                    : 0
                Stream size                              : 135637402
                Stream size                              : 129 MiB (99%)
                Stream size                              : 129.4 MiB
                Proportion of this stream                : 0.99100
                Language                                 : en
                Language                                 : English
                Language                                 : English
                Language                                 : en
                Language                                 : eng
                Language                                 : en
                Audio
                Count                                    : 220
                StreamOrder                              : 1
                Format                                   : AAC
                Format profile                           : LC
                Codec ID                                 : 40
                Codec                                    : AAC LC
                Codec                                    : AAC LC
                Codec/Family                             : AAC
                Codec/CC                                 : 40
                Duration                                 : 49716
                Bit rate mode                            : VBR
                Bit rate                                 : 192000
                Bit rate                                 : 192 Kbps
                Channel(s)                               : 2
                Frame count                              : 2330
                Delay                                    : 0
                Video0 delay                             : 0
                Stream size                              : 1 MiB
                Proportion of this stream                : 0.00860
                Source_StreamSize_Proportion             : 0.00861
                Language                                 : en
                Language                                 : English
                Language                                 : English
                Language                                 : en
                Language                                 : eng
                Language                                 : en
                • 5. Re: MP4 (h.264) changes in CC from CS6
                  Ok, good to know it is just this single file. That helps narrow it down a bit and make me wonder if we shouldn't look at the source file(s) as well. You mentioned it was ProRes, correct? Are you coming from a single file or a Premiere Pro project with ProRes sources? I'm leaning towards there being a problem in the source material we are having a problem with and end up handling it poorly.
                  What if you convert the source to an intermediary format (just as a test) then to the Roku-compatible file? Does that get around the issue? I know it's a pain to have to go through that extra step, but that might help us narrow down what is going on here.
                  • 6. Re: MP4 (h.264) changes in CC from CS6
                    As senior editor for Cortina Productions I've instituted a practice of exporting from Premiere Pro production quality export files for all stages of a project. The final "Online" master files are usually ProRes HQ or ProRes 4444, sometimes high bit depth TGA or PNG image sequences.
                    All three acts of this exhibit's film were first output to ProRes 4444. These production master files are then further encoded to delivery files for use on-site, in this case they are MP4 at 24 Mbps. All three ProRes 4444 production masters were made by Premiere CC.
                    Act 1 and Act 2's ProRes 4444 master exports were encoded to MP4 using CC AME and work perfectly. The master export file from Premiere for Act three was encoded through both CS6 AME and CC AME and only the CS6 AME MP4 encode works. The source file for both encodes of Act 3 are identical. Knowing this, do you still want me to process to an intermediate?
                    Our hardware integrator for this project experienced the problem on two different XD1030s. I will ask if we have one in-house we can pull for further testing...
                    • 7. Re: MP4 (h.264) changes in CC from CS6
                      Ok, an intermediate file probably won't be much help then. Could you provide me with the bad file? I will log a bug on it and let our developers take a look. It may also be helpful to provide a known good file. It isn't necessary to log a bug, but might save time if they end up asking for an example of one that works as we don't have this particular device in-house.
                      • 8. Re: MP4 (h.264) changes in CC from CS6
                        These files must remain private. TNord, it would be great if you could provide me with info for a secure file server for uploading. Total data set is under 1/2 GB.
                        • 9. Re: MP4 (h.264) changes in CC from CS6
                          fisk303 Community Member
                          Just wondering if this was resolved?
                          I am getting similar issues all day, and taking a few brightsign's home to test.
                          I might first try roll back to cs6 this evening.
                          Gulp show opens tomorrow!
                          • 10. Re: MP4 (h.264) changes in CC from CS6
                            I'm having better luck by changing the MP4 profile to baseline (formerly Main).
