• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Single Page Continuous Setting
Community Beginner ,
Oct 21, 2013 Oct 21, 2013
    How do you save this as a permanent setting so that you can scroll quickly as opposed to the slow scrolling which appears to be the default setting?  I am using Acrobay Pro 9.5.5.
Every time I select it under View - Page Display it resets when I open a new pdf.
TOPICS
How to
Views
36.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here , Apr 10, 2024 Apr 10, 2024
THANK YOU, GEORGE_JOHNSON!!!!!!! That fixed my problem!!
[Edit > Preferences > Accessibility > Always Use Page Layout Style > Single Page Continuous]
Votes
Translate
Translate
LEGEND ,
You can only set the default; if a PDF file wishes to override that with another setting, it will.
Votes
Translate
Translate
Report
Report
Oct 22, 2013 Oct 22, 2013
Single Page seems to be the default as that is what is selected every time I open up a pdf.  How do I set Single Page Continuous as the default?
Votes
Translate
Translate
Report
Report
LEGEND ,
Preferences > Page Display > Page Layout
Votes
Translate
Translate
Report
Report
Oct 23, 2013 Oct 23, 2013
Thanks.  I set Single Page Continuous now as the default yet all pdfs still are set to Single Page when I open them.
Not sure why this is so difficult.  Any idea why it would not be using the default setting?
Votes
Translate
Translate
Report
Report
LEGEND ,
As stated earlier, if a PDF file wishes to override that with another setting, it will.
If you want to test this with a PDF that doesn't override, here is one: http://www.adobe.com/security/pdfs/riskcompliance_faq.pdf
Votes
Translate
Translate
Report
Report
I guess what I am looking for then is some idea of what other settings may be overriding the default setting.
Votes
Translate
Translate
Report
Report
LEGEND ,
It is per document. File >Properties ... Open Options
Votes
Translate
Translate
Report
Report
Oct 24, 2013 Oct 24, 2013
I don't have an Open Options tab, only Initial View under File > Properties.  Page Layout under Initial View is set to default, which to me says that it should use my default setting under Preferences > Page Display > Page Layout.  It does not however  Even when I select Single Page Continuous under Page Layout > File > Initial View, it still doesn't work.  Same thing for the Risk Compliance file that you posted.  It scrolls quickly in the browswer but when I download the file it does not scroll quickly.    Page Layout > File > Initial View in the downloaded Risk Compliance doc is set to Default and the only way to get it to scroll quickly once downloaded is to manually change to Single Page Continuous under View > Page Display.  Any ideas?
Votes
Translate
Translate
Report
Report
LEGEND ,
Oct 28, 2013 Oct 28, 2013
To override a setting that's specified in the document, you can set the following user preference: Edit > Preferences > Accessibility > Always Use Page Layout Style > Single Page Continuous
Votes
Translate
Translate
Report
Report
New Here ,
Apr 01, 2015 Apr 01, 2015
Yes, I have a similar problem.  I just tried all your suggestions and it still defaults to 'single page'.  Really frustrating when you are trying to view a large document on a small laptop screen.
Votes
Translate
Translate
Report
Report
New Here ,
Also tried downloading the Adobe Acrobat 9.5.5 fix but it does not seem to recognise my AA 9.0 Pro file so can't do it.
Votes
Translate
Translate
Report
Report
LEGEND ,
With Acrobat 9 you have to install each fix in turn - about 20 of them.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 13, 2015 Apr 13, 2015
Thanks, George_Johnson. That did solve it for me.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 15, 2018 Mar 15, 2018
This isn't working for me. It continues to show the page breaks, which looks wonky.
I've changed Page Display and Accessibility under Acrobat Preferences, and Properties of the PDF I'm creating from Clipboard. All are set to Single Page Continuous, but the page breaks are still there.
Any other ideas?
Thanks!
Roshana
Votes
Translate
Translate
Report
Report
Community Expert ,
You mean the dotted line between pages? If so, you can't hide it in Acrobat or Reader.
Votes
Translate
Translate
Report
Report
New Here ,
Right the dotted line and the big spaces caused by the page break.
Bummer.
Thanks for answering so quickly, though!
Roshana
Votes
Translate
Translate
Report
Report
New Here ,
Jan 17, 2020 Jan 17, 2020
Untick "Show Gaps Between Pages" under View > Page Display and those grey gaps will disappear (which were irritating to me too).
The dashed lines which subsequently appear can't be switched off, but you can always print your document on a single, custom size page (current height * number of pages) which then won't have breaks at all.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 02, 2021 Feb 02, 2021
Ah!  This solved the issues I was having.  Thank you.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Votes
Translate
Translate
Report
Report
Explorer ,
Dec 15, 2015 Dec 15, 2015
thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 08, 2024 Jan 08, 2024
Hi. Under Preferences > Accessibility, there is an override setting, to force PDFs to use a particular layout by default. I'd check that first, see whether it's activated and, if so, whether it's what you want.
I appreciate this is 11 years after your question but if I just surfed on in, others might too.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 28, 2024 Mar 28, 2024
I selected single page continuous in page display and accessibility with no effect, but then did the following:
Hhamburger drop down menu-->View-->Page Display--> Enable Scrolling.
That did the trick.
Votes
Translate
Translate
Report
Report
