4 Replies Latest reply on Oct 22, 2013 12:02 PM by tribule
    Omniture and ColdFusion 10
      We are running ColdFusion 10 application server and using Omniture in our application. Since upgrading to CF 10, we have been getting the following error:
      Oct 19, 2013 3:43:30 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      INFO: Cookies: Invalid cookie. Value not a token or quoted value
      Maybe there is an easier solution to rid ourselves of this error, but this is what I've found.
      I have already pinpointed the issue, which is with the format of Omniture's one cookie which contains brackets. We reached out to them about chaning that format, and they replied the couldn't and that no one else is having the issue. I have found that at least other Tomcat users are having the same issue and it had been suggested to edit a setting. So one our options for eliminating this issue is to adjust the setting in Tomcat that is bult-in to CF 10. From what I've gathered I need to add ALLOW_HTTP_SEPARATORS_IN_V0 to my configuration and set it to true. I've found configuration files for Tomcast in the CF runtime directory. And I suspect I need to add some code to server.xml.
      At this point, I'm not sure how to include the setting or if I'm correct about the proper config file.
      If anyone can help me resolve this issue, it will be greatly appreciated.
