16 Replies Latest reply on Jan 30, 2017 8:31 AM by carved151
    PDF without extensive data "Document Overhead"
    MarioMari Level 1
      Hi!
      How do I create in Indd a PDF without additional data "Document Overhead"? These data are very comprehensive and greatly increase the file size (68 MB)
      I use the PDF sets to create the file:
      Description
          [Based on 'Adobe PDF 1.7 Arch 96 ppi'] [Based on '[PDF/X-4:2008]'] Use these settings to create Adobe PDF documents that are to be checked or must conform to PDF/X-4:2008, an ISO standard for graphic content exchange.  For more information on creating PDF/X-4 compliant PDF documents, please refer to the Acrobat User Guide.  Created PDF documents can be opened with Acrobat and Adobe Reader 5.0 and later.
      PDF Preset: Adobe PDF 1.7 Arch 96 ppi
      Compatibility: Acrobat 8/9 (PDF 1.7)
      Standards Compliance: None
      General
          Pages: All
          Spreads: Off
          Generate Thumbnails: Off
          Optimise PDF: On
          Create Acrobat Layers: Off
          Export Layers: Visible and Printable Layers
          Include Bookmarks: On
          Include Hyperlinks: On
          Export Nonprinting Objects: Off
          Export Visible Guides and Baseline Grids: Off
          Create Tagged PDF: Off
          Interactive Elements: Do Not Include
      Compression
          Colour Images
              Bicubic Downsample at: 96 ppi
              for images above: 96 ppi
              Compression: JPEG
              Tile Size: N/A
              Quality: High
          Greyscale Images
              Compression: JPEG
              Tile Size: N/A
              Quality: High
          Monochrome Images
              Bicubic Downsample at: 600 ppi
              for images above: 600 ppi
              Compression: CCITT Group 4
          Compress Text and Line Art: On
          Crop Image Data to Frames: On
      Marks and Bleeds
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Colour Bars: Off
          Page Information: Off
          Page Mark Type: Default
          Weight: 0.25 pt
          Offset: 2.117 mm
          Use Document Bleed Settings: Off
          Bleed Top: 0 mm
          Bleed Bottom: 0 mm
          Bleed Inside: 0 mm
          Bleed Outside: 0 mm
          Include Slug Area: Off
      Output
          Colour Conversion: Convert to Destination
          Destination: eciRGB v2
          Profile Inclusion Policy: Don't Include Profiles
          Simulate Overprint: N/A
          Output Intent Profile Name: N/A
          Output Condition: N/A
          Output Condition Identifier: N/A
          Registry Name: N/A
      Advanced
          Subset Fonts Below: 100%
          Omit PDF: Off
          Omit EPS: Off
          Omit Bitmap Images: Off
          Transparency Flattener Preset: N/A
          Ignore Spread Overrides: N/A
      Security
          N/A
      Warnings
      PDF 68 MB:
      In Adobe Acrobat Pro I can get rid of these data by optimization of the document and reduces the file to size 16 MB!?
      After optimize PDF in Acrobat PDF 16 MB!
      How to create a PDF straight from the indd? Which settings are responsible for these?
      Regards!
