0 Replies Latest reply on Oct 28, 2013 2:06 PM by bhadra123321
    Incompatible signature after creating a new Flex mobile project in Flashbuilder 4.6
    bhadra123321
      When I create a new flex mobile project and try to build it right away it gives me this error
      1144: Interface method initialize in namespace mx.core:IUIComponent is implemented with an incompatible signature in class utest.
      I have tried reinstalling Flash Builder and even upgraded from 4.5 to 4.6 to try and resolve this problem.
      I have also tried using different versions of the Adobe Air sdk (I'm currently using Air 3.4).
      Here is the projects mxml file, if that helps although it doesnt have anything but the generated code.
      utest.mxml
      <s:ViewNavigatorApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                  firstView="views.utestHomeView" applicationDPI="160">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
      </s:ViewNavigatorApplication>
      views.utestHomeView.mxml
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView">
          <fx:Declarations>
          </fx:Declarations>
      </s:View>
      Also I am running Flash Builder 4.6 on Windows 7 32-bit
      Thanks in advance for the help
      Edit:
      I have now tried the flash builder 4.7 trial and even 4.6 on a different machine, both were clean installs, and I have found that when i create a new project it does compile
      until I get an error, and this can be any error, then after I fix that error it gives me the same error as before
