1 Reply Latest reply on Oct 23, 2013 7:23 PM by A.T. Romano
    video import problem
    tkennedy41
      when i add a video from my organizer to my project it is reduced in size from over 9 minutes to less than 2 minutes. how can i fix this problem?
        • 1. Re: video import problem
          A.T. Romano Level 7
          tkennedy41
          What happens if you import the video from a hard drive save location instead of the Elements Organizer?
          But, that is getting ahead of the story, lots of missing details. Nonetheless, the answer to my lead in question is important.
          1. What version of Premiere Elements are you using and on what computer operating system is it running?
          2. What are the video and audio properties of these files...video and audio compression, frame size, frame rate, file extension, pixel aspect ratio, duration, etc.?
          3. What are you or the project setting as the project preset for this import so that the properties of the import match those of the project preset?
          Is the issue that you are presenting
          a. It worked before but not now
          or
          b. It never worked before.
          4. What went missing in the transfer of the video from the Elements Organizer to the Premiere Elements workspace?
          a. the whole file was cut from 9 minutes to less than 2
          or
          b. just the video was affected or just the audio was affected?
          Let us start here and then decide what needs to be done.
          Thanks.
          ATR
