1. Re: [JS] XML transformation
Gonterman1201 Oct 24, 2013 8:06 AM (in response to Philippe Ruelle)This is how I read a xml file.
var myXML_Hot="/Volumes/This is a link to your folder/"+myString+"-000-14.xml";
xmlPath = File(myXML_Hot);
if (xmlPath.open('r')) {
xmlText = xmlPath.read();
xmlPath.close();
x = XML(xmlText);
s = x.CUSTOMERID.toString(); /// the name after x is the tag
csa = x.CSRNAME.toString();
mySchoolName.text=s;
2. Re: [JS] XML transformation
Philippe Ruelle Oct 25, 2013 1:57 AM (in response to Gonterman1201)Thank you, I found what helps me, here is the code, I do not know if this is the best codes.
But I find it hard to test if a tag exite.myXMLFile = File("~/Desktop/content/content.opf");
myXMLFile.open('r');
myXMLFile.encoding = "UTF-8";
var currentXML = new XML(myXMLFile.read());
//maLectureContent(myXMLFile);
$.writeln (maLectureContent(myXMLFile));function maLectureContent(XMLFile) {
default xml namespace = "xmlns\:dc=\"http\://purl.org/dc/elements/1.1/\"";
var refFile = XMLFile;
var XMLHeader = '';
var XMLWorkbookHeader = "<\?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>";
var XMLWorkbookHeader2 = "xmlns=\"http\://www.idpf.org/2007/opf\" unique-identifier=\"bookid\" version=\"2.0\"";
if(refFile != null) {
refFile.open("r");
var XMLToParse = refFile.read();
refFile.close();
var XMLsettings = XML.settings;
XMLsettings.prettyPrinting = false;
XML.setSettings(XMLsettings);
XMLToParse = XMLToParse.replace(XMLWorkbookHeader,"");
XMLToParse = XMLToParse.replace(XMLWorkbookHeader2,"");
$.write (XMLToParse);
var XMLData = new XML(XMLToParse);
XMLToParse = null;
} else {
alert("Error opening XML file.");
var test = {title:((XMLData.metadata['dc:title'].length() != 0)? XMLData.metadata['dc:title']:"vide"),
desscription:((XMLData.metadata['dc:description'].length() != 0)? XMLData.metadata['dc:description']:"vide"),
rights:((XMLData.metadata['dc:rights'].length() != 0)? XMLData.metadata['dc:rights']:"vide"),
creator:((XMLData.metadata['dc:creator'].length() != 0)? XMLData.metadata['dc:creator']:"vide"),
language:((XMLData.metadata['dc:language'].length() != 0)? XMLData.metadata['dc:language']:"vide"),
date:((XMLData.metadata['dc:date'].length() != 0)? XMLData.metadata['dc:date']:"vide"),
publisher:((XMLData.metadata['dc:publisher'].length() != 0)? XMLData.metadata['dc:publisher']:"vide"),
subject:((XMLData.metadata['dc:subject'].length() != 0)? XMLData.metadata['dc:subject']:"vide"),
identifier:((XMLData.metadata['dc:identifier'].length() != 0)? XMLData.metadata['dc:identifier']:"vide")};//var test = XMLData.spine.itemref[2].@idref;
return (test["date"]);}
