3 Replies Latest reply on Nov 12, 2013 2:32 AM by elainecc
    Edge Animation on ipad flashes at start
    iwantfreehandback
      Hi there,
      i have several Edge Animations embedded in a Webview which is running in an ipad app.
      the animations are triggered by a button to start (although the same error occurs using autostart...), when they start
      they show a white or a black "Flash" (depends on the given background). Is this a known issue?
      I´ve tried setting the background to transparent, but that doesn´t solve the problem.
      The animations themselves are nothing fancy, no .svg´s for example. Just moving pngs, mostly.
      Everything else runs very smooth on the ipad, except that start-flash.
      Any suggestions? Thanks in advance.
      (you can image how hard it is to do a websearch containing "Edge Animation" and "Flash" ).
      UPDATE: I forgot to mention that the Animations DONT show that behavior when tested in Safari on the Desktop-Computer.
      It only happens in the App (webview).
