• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Publishing problem
New Here ,
Dec 28, 2007 Dec 28, 2007
Hello,
Im having trouble publishing - I'm getting an error saying that I cannot connect to the server - very rarely will it connect and update - I did not setup robohelp or the server - there is another departent that uses robohelp and they have the same problem - it seems that only one of us can publish once a day - does anyone know how to correct this problem?
This is Robohelp 6.
Views
790
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Welcome to the forum.
I don't think this is a RoboHelp problem. Either RH will allow you to publish or it will not. Once the setup is OK, then generally you can publish anytime. Sometimes a publishing has been cancelled message appears but that is a different thing.
If you could not connect ever, then we could look at the settings, but as they sometimes work that pretty much rules them out.
Have you tried connecting using an FTP program? Have you asked you IT people to look into it? Has it always been this way?
Votes
Translate
Translate
Report
Report
New Here ,
hey peter,
It has always been this way according to the person that was doing it before me - we asked IT to look into it and I think they are trying to contact adobe support - I have tried pinging the server and it responds and I have tried FTPing through explorer and I canot make a connection
Votes
Translate
Translate
Report
Report
Community Expert ,
I would hold off contacting Adobe Support until you know it is their problem, unless you have a maintenance contract.
Try a free FTP program such as FileZilla and see if that will connect.
If you still cannot connect with that, that put it beyond doubt that the problem is internal and for your IT people to sort out, not Adobe.
Votes
Translate
Translate
Report
Report
New Here ,
peter,
I tried the program and I can log into the server but it doesn't show a directory or any files - thank you for your help
Votes
Translate
Translate
Report
Report
Community Expert ,
Pretty much proves it's an internal issue for your IT to resolve. Have they checked your permissions?
Votes
Translate
Translate
Report
Report
New Here ,
that was one of the first things I asked and I have not received an answer but I figured it wasn't the problem since it connects and publishes sometimes
Votes
Translate
Translate
Report
Report
Community Expert ,
I can see your logic but equally seeing the drive sometimes and not others is not logical.
Votes
Translate
Translate
Report
Report
Engaged ,
I wonder...
Could there be a limit to the number of users who can simultaneously access the server? We have an issue like that here, although it affects an aspect of Word, not anything to do with RoboHelp. If there are more than 10 connections, everybody else is out of luck.
G
Votes
Translate
Translate
Report
Report
New Here ,
Jan 02, 2008 Jan 02, 2008
I, like you, had others set up Robo software (x5) and Robo Engine. I have experienced that "cannot connect to server" error message and usually it is because of the server. I've had RH tech support help on the line as well as having them ping the server which, if it responds to pings doesn't mean that the server is "talking". Our IT folks do the same thing and it's frustrating. My successful fixes have been to power down the server and reboot. Hope that helps you in some way.
Donna
SunTrust Mortgage
Votes
Translate
Translate
Report
Report
New Here ,
Jan 09, 2008 Jan 09, 2008
I recently found out that the other departent uses Robohelp 5 and I use 6 - they also have multiple projects where I only have one - this other department has had robohelp projects for 3 years and this problem has always been there - rebooting the server is not an option since many critical business services also run on it - could this new information point to any other solutions?
Votes
Translate
Translate
Report
Report
LEGEND ,
Would it be possible that when one department publishes that they are not "releasing" it after they are finished? This is one for your IT people to check out. It may be worth them checking things as both your departments publish to see what is happening. Donna's suggestion would seem to fix things in the short term. Could your IT people schedule a reboot during some downtime of the business?
Votes
Translate
Translate
Report
Report
New Here ,
Sorry I forgot to add to the last post that the server gets rebooted every night - the other departent has code in a topic to redirect it to a html file on another drive and just updates this file and saves it - i setup a topic in my project to do this also for updates to get info to the masses, but its not the right solution to the problem
Votes
Translate
Translate
Report
Report
LEGEND ,
So is there some rhyme or reason to your woes? Does the first publish always work after the o/n reboot? Is it only subsequent publishes that have the problem? Either way, I'd get your IT people to run diagnostics whilst attempts are made to publish to see what is happening.
Votes
Translate
Translate
Report
Report
New Here ,
no theres no rhyme or reason - some days I get the error I cant connect and then I would reboot, reenter the server info and it would work - someties I just reentered the server info - this has only happened about 3 times though
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
With the information you have provided I definitely say this is IT not RH related. There must be something running on the server causing these blips.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
