I'm trying to deploy Flash Player via SCCM for both ActiveX and Plugin based browsers. I am encountering a situation where if the client previously had the same version of flash player installed, the ActiveX installation fails with error code 1722. I have a script I'm working with that runs the Adobe Flash uninstaller, as well as checks the registry to ensure the "HKLM:\SOFTWARE\Macromedia\FlashPlayer\SafeVersions" key is not present. However, whether running the ActiveX installer via the powershell script or manuallly runnning it, the installation fails to complete. The Plugin based installer (for Firefox, etc.) functions normally and I am able to use Flash Player on those browsers. This only affects my clients below Windows 8, as the ActiveX install component is not being run on those systems.
(Re)Installation Script:
http://pastebin.com/bLXzqh6h
MsiInstaller Event:
Product: Adobe Flash Player 11 ActiveX -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\TSTUSR~1\AppData\Local\Temp\InstallAX_11_9_900_117.exe, command: -install -msi
FlashInstall Log:
=O====== M/11.9.900.117 2013-10-25+17-15-38.950 ========
0000 00000010 "C:\Users\TSTUSR~1\AppData\Local\Temp\{68B39BF0-8050-44C9-98B2-3F1CE5794FB5}\InstallFlashPlayer.exe" -uninstall activex
0001 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0002 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0003 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0004 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0005 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0006 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0007 00001021
0008 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0009 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0010 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
=X====== M/11.9.900.117 2013-10-25+17-15-39.481 ========
=O====== M/11.9.900.117 2013-10-25+17-16-58.073 ========
0000 00000010 "C:\Users\TSTUSR~1\AppData\Local\Temp\{FAFFD6BF-3AD9-453F-ACD0-CAAB5614F3A6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000012
=X====== M/11.9.900.117 2013-10-25+17-17-03.105 ========
=O====== M/11.9.900.117 2013-10-25+21-01-57.533 ========
0000 00000010 "C:\Users\TSTUSR~1\AppData\Local\Temp\{4AB1083B-E5B5-4F47-925E-F4F6B2A976FF}\InstallFlashPlayer.exe" -uninstall plugin
0001 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0003 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0006 00001021
0007 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0008 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0009 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0010 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0011 00001036 Software\Opera Software/Last CommandLine 2
0012 00001036 Software\Opera Software/Last CommandLine 2
0013 00001036 Software\Opera Software/Plugin Path 2
0014 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.9.900.117 2013-10-25+21-01-59.788 ========
=O====== M/11.9.900.117 2013-10-25+21-02-01.847 ========
0000 00000010 "C:\Users\TSTUSR~1\AppData\Local\Temp\{9441604B-5560-41F9-9927-6FF81899F8A0}\InstallFlashPlayer.exe" -force -uninstall
0007 00001021
0011 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0012 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
0013 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0014 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0015 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0016 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0017 00001018
0018 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0019 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0020 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0021 00001019
0022 00001020
0023 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0024 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0025 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0026 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0027 00001021
0028 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0029 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0030 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0031 00001048
0032 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0033 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0034 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0035 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
0036 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0037 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0038 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0039 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0040 00001036 Software\Opera Software/Last CommandLine 2
0041 00001036 Software\Opera Software/Last CommandLine 2
0042 00001036 Software\Opera Software/Plugin Path 2
0043 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.9.900.117 2013-10-25+21-02-01.965 ========
=O====== M/11.9.900.117 2013-10-25+21-02-30.879 ========
0000 00000010 "C:\Users\TSTUSR~1\AppData\Local\Temp\{1E0E5E90-488A-4F9D-A288-4E9FBD7EB3A5}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0003 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000012
=X====== M/11.9.900.117 2013-10-25+21-02-35.663 ========
=O====== M/11.9.900.117 2013-10-25+21-02-51.814 ========
0000 00000010 "C:\Users\TSTUSR~1\AppData\Local\Temp\{58DCA152-495D-4D91-95F7-3A6CE51CDB01}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0004 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0006 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0007 00001036 Software\Opera Software/Last CommandLine 2
0008 00001036 Software\Opera Software/Last CommandLine 2
0009 00001036 Software\Opera Software/Plugin Path 2
0010 00001036 Software\Opera Software/Plugin Path 2
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_9_900_117.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_Plugin.exe
0013 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0015 00000012
=X====== M/11.9.900.117 2013-10-25+21-02-56.415 ========
