1. Re: PDF files into InDesign Not Working
Peter Spier Oct 26, 2013 2:36 PM (in response to cecelia63)Show the import options when you place and make sure the crop option is set to something that actually exists in the PDF, Media, Art or Bounding Box would be likely choices.
2. Re: PDF files into InDesign Not Working
cecelia63 Oct 26, 2013 9:45 PM (in response to Peter Spier)Peter, thank you very much for replying. I tried the import options with all three settings but none changed the "Failed to open the pdf file" message. I am not sure how to know if the pdf has any of these. I have tried creating the pdf through PowerPoint and Word with "Paste As" and also through Preview using the clipboard and all behave the same. On the bright side, I have figured out how to use Preview to create a high quality jpeg that seems to be sufficient IQ (highest quality and 300 dpi).
Thanks again, Cecelia
3. Re: PDF files into InDesign Not Working
G.Hoffmann Oct 27, 2013 1:55 AM (in response to cecelia63)Cecelia,
I'm just curious, why don't you place your Excel file in the InDesign document
directly? There it can be edited (size of table cells, text, font...).
I don't have Excel, Word and Powerpoint. If somebody sends me an (always
unwanted) Excel file, then I can view it by InDesign.
For advanced editing, Illustrator might be recommended, but I didn't test it.
Best regards --Gernot Hoffmann
4. Re: PDF files into InDesign Not Working
Willi Adelberger Oct 27, 2013 3:38 AM (in response to G.Hoffmann)No, formatting Excel files in Illustrator is not a good idea. But formatting it in InDesign would give better results than the way around PowerPoint, Preview and ultimately InDesign. None of those programs except InDesign has reliable PDF capabilites, so I would avoid them here.
5. Re: PDF files into InDesign Not Working
G.Hoffmann Oct 27, 2013 4:58 AM (in response to Willi Adelberger)Willi,
I should have tested it, but I didn't...: Neither CS2 nor CS6 Illustrator can
open or place an actual *.XLS. Can this be confirmed generally?
6. Re: PDF files into InDesign Not Working
Willi Adelberger Oct 27, 2013 5:03 AM (in response to G.Hoffmann)The exchange from Excel to AI is very poor. A little bit can be done in the charts table, but Illustrator has no tool to support tables anyway.
7. Re: PDF files into InDesign Not Working
Peter Spier Oct 27, 2013 6:01 AM (in response to cecelia63)Cecelia,
While I agree that there is probably not a reason for importing PDF over simply importing the Excel table in a general sense, I suspect there may be soemthing specific to lo lead you to your workflow, and I'd like to figure out why your PDF doesn't import. Would you be willing to send me one of them? I'll send you an upload link.
8. Re: PDF files into InDesign Not Working
cecelia63 Oct 28, 2013 6:32 AM (in response to Peter Spier)Peter, Yes, I would love to send you a file that works from a few weeks back and one that does not. Thank you!
To the other responders, thanks for the ideas. My project is a knitting book and there will be approximately 200 tables. The Adobe table-formatting tools are not familiar to me, and the PowerPoint formatting tools are both familiar to me and pretty easy to use. I have also had many problems over the years with embedded Excel files within Microsoft Office, and I would be concerned about the stability of the file.
The imported pdf files from PowerPoint or Word look great in InDesign.
Thanks again!
Cecelia
9. Re: PDF files into InDesign Not Working
Peter Spier Oct 28, 2013 6:38 AM (in response to cecelia63)I sent the link yesterday. Check your email for a message from Adobe Forums telling you that you have a private message from me.
10. Re: PDF files into InDesign Not Working
Peter Spier Oct 28, 2013 7:18 AM (in response to Peter Spier)I'm getting the same results here that you are getting, and I can't see any reason for it. I was able to open the PDF in Illustrator (Not something I recommend most of the time, but this file has no text) and resave without any edits, and it placed fine. I think it must be something that Mac Quartz is adding or leaving out, but I can't say what.
These are really charts rather than what we normally think of as tables. Do you have Illustrator? It would be fairly easy to reproduce these in Illustrator directly (and not that difficult in ID using traditional tables with different fills in empty cells), but if you are comfrotable working in Excel it is commonly recommended that Excel charts be pasted into Illustrator and then saved as PDF there.
11. Re: PDF files into InDesign Not Working
cecelia63 Oct 28, 2013 7:38 AM (in response to Peter Spier)Peter, thank you! I am not crazy!
I will try pasting the PowerPoint table into Illustrator. I did try pasting it into InDesign but it was completely garbled. I can also paste from Excel, but if I need to edit the table format in Illustrator i fear a the learning curve.
I won't be able to try this today, but I will repoat as soon as i can.
12. Re: PDF files into InDesign Not Working
cecelia63 Oct 29, 2013 6:38 AM (in response to cecelia63)Peter, When you said that Mac Quartz might have been leaving something out, you gave me a clue that Apple was the problem. I upgraded to Mavericks last night and my workflow is now working again! Thank you so much for you help!
Best,
Cecelia
