7 Replies Latest reply on Oct 27, 2013 9:53 AM by TᴀW
    Find sibling file not working on Mac
    TᴀW Adobe Community Professional & MVP
      Imagine I've got a folder on my desktop containing 2 files. One is called "File1.1.1.jsx", and the other is called "File2.2.2.jsx".
      I want the first file to get a handle on the second file. So the first file ("File1.1.1.jsx") contains the following script
      #target estoolkit
       var otherFile = new File("File2.2.2.jsx");
       alert (otherFile.exists);
      On Windows this works fine, and the alert shows "true".
      On Mac, though, the alert shows "false", so somebody has told me.
      I don't know why. I don't have a Mac to test this on. Can anyone explain to me what's going on? Why is this working on Windows and not Mac?
      Ariel
        • 1. Re: Find sibling file not working on Mac
          pixxxel schubser Most Valuable Participant
          [Ariel] schrieb:
          #target estoolkit
          Ariel
          IMHO I don't think, this can work on Windows.
          If any, then you need a file path to your file like:
          #target estoolkit
          var otherFile = new File ("~/Desktop/TestFolder/File2.2.2.jsx");
          And I never use a file name like 2.2.2.jsx   Never, never!
          Better is 222.jsx or 2_2_2.jsx
          • 2. Re: Find sibling file not working on Mac
            Thanks. It does work on Windows. It is not necessary to add the path for
            files that are in the same folder as the script that is being run.
            My question is why does it not work on Mac?
            Ariel
            • 3. Re: Find sibling file not working on Mac
              Pickory Level 3
              Hello,
              I don't know why it works on Windows, I can confirm it does NOT work on Mac.
              I have always used some code borrowed from FindChangeByList.
              function myFindFile(myFilePath){
                        var myScriptFile = myGetScriptPath();
                        var myScriptFile = File(myScriptFile);
                        var myScriptFolder = myScriptFile.path;
                        myFilePath = myScriptFolder + myFilePath;
                        if(File(myFilePath).exists == false){
                                  //Display a dialog.
                                  myFilePath = File.openDialog("Choose the file containing your find/change list");
                        return myFilePath;
              function myGetScriptPath(){
                        try{
                                  myFile = app.activeScript;
                        catch(myError){
                                  myFile = myError.fileName;
                        return myFile;
              P.
              • 4. Re: Find sibling file not working on Mac
                Sorry, your way doesn't work on Windows:
                [Ariel] schrieb:
                files that are in the same folder as the script that is being run …
                and with a path it works correctly on my Windows:
                What are you doing differently?
                Does your script snippet really run standalone?
                • 5. Re: Find sibling file not working on Mac
                  Strange, pixxxel. It definitely works for me on Windows. But I see that it's not working for you. Not sure why. But anyway, it doesn't matter. Pickory has pointed me in the right direction.
                  This should always work to get the sibling of the active script file:
                  #target estoolkit
                  otherFile = new File((Folder(app.activeScript).parent)+"/File1.1.1.txt");
                  alert(myFile.exists);
                  Thanks both. I think this solves my prob (without delving into the details of why it was or wasn't working before).
                  Ariel
                  • 6. Re: Find sibling file not working on Mac
                    My pleasure.
                    Does this variant also works for you correctly?
                    #target estoolkit
                    var otherFile = File(File($.fileName).parent.fullName +"/File1.1.1.txt");
