13 Replies Latest reply on Oct 30, 2013 7:58 AM by ProDesignTools
    Error installation - Payload path does not exist and no media record specified.
    Ang Yu Kiong Level 1
      Hi all,
      When I tried to install the photosohop CS5, the below errors keep prompting out. Can anyone help me solve these errors! Thanks!
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 70 error(s), 58 warning(s)
      ERROR: DS011: Payload path does not exist and no media record specified.
      WARNING: DW024: The payload: Adobe Photoshop CS5 Core  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} requires a UI parent with following specification:
                      Family: Photoshop
                      ProductName: Adobe Photoshop CS5 Core_x64
                      This parent relationship is not satisfied, because this payload is not present in this session.
      WARNING: DW025: The payload with AdobeCode:  {A334FDED-DCCA-481E-B226-F902CCC419D2} has recommended dependency on:
                      Family: Adobe Web Suite CS5
                      ProductName: Adobe Media Encoder CS5 X64
                      MinVersion: 0.0.0.0
                      This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
                      Removing this payload from the dependency list.
                      ProductName: Adobe Media Encoder CS5 Dolby WRAPPER X64
                      MinVersion: 0.0.0.0
                      ProductName: Adobe Media Encoder CS5 PCI WRAPPER X64
                      MinVersion: 0.0.0.0
      ERROR: DW025: The payload with AdobeCode:  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} has required dependency on:
                      Family: CoreTech
                      ProductName: Adobe Player for Embedding x64
                      MinVersion: 0.0.0.0
                      Removing this dependency from list. Product may function improperly.
                      Family: Shared Technology
                      ProductName: Photoshop Camera Raw (64 bit)
                      MinVersion: 0.0.0.0
                      Family: CoreTech
                      ProductName: AdobeCMaps x64 CS5
                      MinVersion: 0.0.0.0
                      Family: CoreTech
                      ProductName: Adobe Linguistics CS5 x64
                      MinVersion: 0.0.0.0
                      Family: CoreTech
                      ProductName: AdobePDFL x64 CS5
                      MinVersion: 0.0.0.0
                      Family: CoreTech
                      ProductName: AdobeTypeSupport x64 CS5
                      MinVersion: 0.0.0.0
                      Family: CoreTech
                      ProductName: Adobe WinSoft Linguistics Plugin CS5 x64
                      MinVersion: 0.0.0.0
      WARNING: DW025: The payload with AdobeCode:  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} has recommended dependency on:
                      MinVersion: 0.0.0.0
      WARNING: DW025: The payload with AdobeCode:  {E8815668-95B0-443D-AC92-2BFD7DD8F16A} has recommended dependency on:
                      MinVersion: 0.0.0.0
      ERROR: DW025: The payload with AdobeCode:  {F9766AC1-1461-1033-B862-DF8FE1C033BE} has required dependency on:
                      Family: InDesign
                      ProductName: Adobe InDesign CS5 Icon Handler x64
                      MinVersion: 0.0.0.0
      WARNING: DW025: The payload with AdobeCode:  {F9766AC1-1461-1033-B862-DF8FE1C033BE} has recommended dependency on:
                      MinVersion: 0.0.0.0
      ----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
      ERROR: Install MSI payload failed with error: 1612 - The installation source for this product is not available. Verify that the source exists and that you can access it.
      MSI Error message:
      WARNING: DW036: Payload cannot be installed due to dependent operation failure
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe CSXS Infrastructure CS5: Install failed
      ERROR: DW050:  - Microsoft_VC90_ATL_x86: Install failed
      ERROR: DW050:  - Adobe Media Player: Install failed
      ERROR: DW050:  - SiteCatalyst NetAverages: Install failed
      ERROR: DW050:  - Microsoft_VC90_CRT_x86: Install failed
      ERROR: DW050:  - Adobe Photoshop CS5 Support: Install failed
      ERROR: DW050:  - Adobe Bridge CS5: Install failed
      ERROR: DW050:  - Microsoft_VC80_ATL_x86: Install failed
      ERROR: DW050:  - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
      ERROR: DW050:  - Creative Suite 5 Master Collection: Install failed
      ERROR: DW050:  - Adobe XMP Panels CS5: Install failed
      ERROR: DW050:  - Adobe Player for Embedding: Install failed
      ERROR: DW050:  - Photoshop Camera Raw: Install failed
      ERROR: DW050:  - AdobeColorCommonSetCMYK: Install failed
      ERROR: DW050:  - AdobeHelp: Install failed
      ERROR: DW050:  - Camera Profiles Installer: Install failed
      ERROR: DW050:  - Adobe Mini Bridge CS5: Install failed
      ERROR: DW050:  - AdobeColorJA CS5: Install failed
      ERROR: DW050:  - Adobe ReviewPanel CS5: Install failed
      ERROR: DW050:  - Adobe BrowserLab CS Live: Install failed
      ERROR: DW050:  - Microsoft_VC90_MFC_x86: Install failed
      ERROR: DW050:  - CSXS Story Extension: Install failed
      ERROR: DW050:  - Suite Shared Configuration CS5: Install failed
      ERROR: DW050:  - Adobe Linguistics CS5: Install failed
      ERROR: DW050:  - PDF Settings CS5: Install failed
      ERROR: DW050:  - DeviceCentral: Failed due to Language Pack installation failure
      ERROR: DW050:  - AdobeTypeSupport CS5: Install failed
      ERROR: DW050:  - AdobeColorVideoProfilesCS CS5: Install failed
      ERROR: DW050:  - AdobeColorCommonSetRGB: Install failed
      ERROR: DW050:  - Adobe Photoshop CS5 Core: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
      ERROR: DW050:  - Adobe CSXS Extensions CS5: Install failed
      ERROR: DW050:  - AdobeOutputModule: Install failed
      ERROR: DW050:  - Microsoft_VC80_CRT_x86: Install failed
      ERROR: DW050:  - Adobe Illustrator CS5: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
      ERROR: DW050:  - AdobeColorEU CS5: Install failed
      ERROR: DW050:  - AdobePDFL CS5: Install failed
      ERROR: DW050:  - HIL Help Search: Install failed
      ERROR: DW050:  - AdobeCMaps CS5: Install failed
      ERROR: DW050:  - AdobeColorNA CS5: Install failed
      ERROR: DW050:  - Required Common Fonts Installation: Install failed
      ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
      ERROR: DW050:  - Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack: Install failed
      ERROR: DW050:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR: DW050:  - AdobeColorPhotoshop CS5: Install failed
      ERROR: DW050:  - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
      ERROR: DW050:  - Adobe Extension Manager CS5: Install failed
      ERROR: DW050:  - AdobeJRE: Install failed
      ERROR: DW050:  - Adobe ExtendScript Toolkit CS5: Install failed
      ERROR: DW050:  - Adobe AIR: Install failed
        • 1. Re: Error installation - Payload path does not exist and no media record specified.
          Ashutosh.Nigam Adobe Employee
          Seems a case of corrupt installation setup. Could you please share more info on Os and method of install (DVD or local copy).
          If DVD then try copying the contents of the DVD to your hard disk.(Create a folder on desktop and copy the contents then initiate setup).
          Regards,
          Ashutosh
          • 2. Re: Error installation - Payload path does not exist and no media record specified.
            My com is Windows 7, 32-bits.
            Previously, I have installed the photoshop cs5 trial version once from the internet. after that, I unistalled the entire photoshop cs5 version from my com. Now I have the DVD and wanted to reinstall the photoshop cs5 again, but the above errors keep prompting out.
            I have tried to copy the contents from the DVD to my desktop, and install, but the errors still occur.
            Thanks!
            • 3. Re: Error installation - Payload path does not exist and no media record specified.
              Unfortunately installation setup on DVD seems corrupt, Hence even your local copy is not working.
              Please download the setup again from Internet and keep a copy of it for future use.
              http://prodesigntools.com/all-adobe-cs5-direct-download-links.html
              Please follow the instructions mentioned carefully.
              Regards,
              Ashutosh
              • 4. Re: Error installation - Payload path does not exist and no media record specified.
                I have followed the instructions and download the products, but there is still error.
                I have downloaded the one that is circled in red. is that compatible with my com?Capture.JPG
                And these are the errors:
                Exit Code: 6
                - 0 fatal error(s), 45 error(s), 41 warning(s)
                          Family: Photoshop
                ----------- Payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 1.0.0.0 -----------
                MSI Error message:
                MSI Error message:
                ----------- Payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding 3.1.0.0 -----------
                ----------- Payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 -----------
                ----------- Payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp 1.0.0.0 -----------
                ----------- Payload: {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 12.0.0.0 -----------
                Thanks.
                • 5. Re: Error installation - Payload path does not exist and no media record specified.
                  It seems there were some issues with extraction of Ps installation files.
                  Please download both files, Navigate to the directory where you saved the installation files and double-click the .exe(file1), this would extract the Ps CS5 installation files.
                  After the files finish extracting, the installer launches automatically. If it doesn’t, go to the folder that contains the extracted files. Double-click Set-up.exe to begin installation.
                    • Follow the onscreen instructions to install .
                    • When prompted for a serial number, enter your serial number and complete the installation.
                  Please let me know if this resolves your issue.
                  Regards,
                  Ashutosh
                  • 7. Re: Error installation - Payload path does not exist and no media record specified.
                    I have tried to download the file 1, but it's states "access denied". I have signed in to my adobe account, turning off the antivirus and firewall, but I still cannot download.
                    Access Denied
                    You don't have permission to access "http://trials2.adobe.com/AdobeProducts/PHSP/12/win32/Photoshop_12_LS1.exe?" on this server.
                    Reference #18.26bed676.1383010395.1173eca2
                    Please advise.
                    • 8. Re: Error installation - Payload path does not exist and no media record specified.
                      Then use the default file extractor in Windows or WinRar/WinZip, Download File 2, extract it and then go to the folder that contains the extracted files. Double-click Set-up.exe to begin installation.
                      Regards,
                      Ashutosh
                      • 9. Re: Error installation - Payload path does not exist and no media record specified.
                        PECourtejoie Adobe Community Professional
                        Hi, Ashutosh, isn't the file one needed as well?
                        Ang Yu, did you follow the whole procedure? If you still have access denied, I suggest posting in the comments of that post.
                        • 10. Re: Error installation - Payload path does not exist and no media record specified.
                          @PECourtejoie,
                          Yes it is needed but it is not available on the site. This is required for extraction of PS installation package.
                          This is the reason i asked Ang to use a extractor software so that he can get the installation files.
                          Regards,
                          Ashutosh
                          • 11. Re: Error installation - Payload path does not exist and no media record specified.
                            I have tried using the extractor software to exract the "file 2". Then I click on the "set up" file...but the errors still exists. Is there anyway to download the "file 1" since it keeps stating "access denied".
                            • 12. Re: Error installation - Payload path does not exist and no media record specified.
                              I would try to resolve it over connect session.
                              Please check your private messages.
                              Regards,
                              Ashutosh
                              • 13. Re: Error installation - Payload path does not exist and no media record specified.
                                ProDesignTools MVP & Adobe Community Professional
                                Please advise.
                                Hi Ang, those direct links all still work fine - we just verified them both...
                                If you are having difficulties downloading, then see this list of suggestions.
                                Hopefully that will help you finish the job.
