1 Reply Latest reply on Oct 29, 2013 6:26 AM by resdesign
    priority of dynamically symbols
    oliverS Level 1
      Hello everybody,
      I wonder if it is possible to manage the hirachie of a dynamically created symbols from the library.
      I have a project in which i often grab symbols on the stage whith the createChildSymbol method.
      But I want to be able to tell them in wich layer order they are on the stage.
      Is it like who comes first has the higher priority as a "layer".
      My question is, is it possible to tell a symbol (which is creates dynamically)  that it is the highes layer on top off all.
      If there is any help I would appreciate it
      THX
      Oliver
        • 1. Re: priority of dynamically symbols
          resdesign Adobe Community Professional & MVP
          Hey Oliver- use z-index. You can give the created symbol an id and then place it at whatever level you want.
          Below is the way you add an id or a class to a created symbol:
          var NewSymbolInstance = sym.createChildSymbol("mySymbol", "Stage");
          NewSymbolInstance.element.addClass("newClassName");
          NewSymbolInstance.element.attr("id","idnew");
          // then you can add the z-index to the symbol - Note: Do not forget the # otherwise it will not work.
          sym.$("#idnew").css({'z-index':'100'});
          This tip was given to me by awesome Zaxist. Let us render to Ceasar what belongs to Ceasar!
          Hope this helps!
