0 Replies Latest reply on Oct 29, 2013 1:05 AM by MichaelZ
    The DataSource service is not available.
    MichaelZ
      Windows Server 2008 R2 Standard + IIS + CF8
      When I access the http://127.0.0.1/CFIDE/administrator/index.cfm, I goet error which says "The DataSource service is not available."
      I googled solution and use the neo-datasource.bak to replace my neo-datasource.xml. But it did not work.
      Could anyone met this error before and give me a solution for this?
      Please see the detailed into below:
      This exception is usually caused by service startup failure. Check your server configuration.
      The error occurred in Application.cfm: line 87
      Called from Application.cfm: line 4
      Called from Application.cfm: line 1
      -1 : Unable to display error's location in a CFML template.
      Resources:
      Browser  Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; WOW64; Trident/6.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729)
      Remote Address  127.0.0.1
      Referrer
      Date/Time  29-Oct-13 12:43 AM
      Stack Trace (click to expand)
      at cfApplication2ecfm1253482620._factor2(E:\cf8_updates\cfusion\wwwroot\CFIDE\administrator\ Application.cfm:87) at cfApplication2ecfm1253482620._factor7(E:\cf8_updates\cfusion\wwwroot\CFIDE\administrator\ Application.cfm:4) at cfApplication2ecfm1253482620.runPage(E:\cf8_updates\cfusion\wwwroot\CFIDE\administrator\A pplication.cfm:1)
      coldfusion.server.ServiceFactory$ServiceNotAvailableException: The DataSource service is not available.  at coldfusion.server.ServiceFactory.getDataSourceService(ServiceFactory.java:76)  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)  at java.lang.reflect.Method.invoke(Method.java:597)  at coldfusion.runtime.java.JavaProxy.invoke(JavaProxy.java:87)  at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2272)  at cfApplication2ecfm1253482620._factor2(E:\cf8_updates\cfusion\wwwroot\CFIDE\administrator\Application.cfm:87)  at cfApplication2ecfm1253482620._factor7(E:\cf8_updates\cfusion\wwwroot\CFIDE\administrator\Application.cfm:4)  at cfApplication2ecfm1253482620.runPage(E:\cf8_updates\cfusion\wwwroot\CFIDE\administrator\Application.cfm:1)  at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196)  at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370)  at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)  at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:33)  at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:214)  at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)  at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)  at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)  at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)  at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:74)  at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)  at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)  at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)  at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)  at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)  at coldfusion.CfmServlet.service(CfmServlet.java:175)  at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)  at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)  at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)  at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)  at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)  at jrun.servlet.FilterChain.service(FilterChain.java:101)  at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)  at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)  at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)  at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)  at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)  at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)  at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)  at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)  at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      Michael
