4 Replies Latest reply on Oct 29, 2013 12:19 PM by A.T. Romano
    Premiere Elements 9 shuts down after edits
    3JK
      I'm using premiere elements 9 and it shuts down when I try to edit clips, it works fine until the edit process. please help!!
        • 1. Re: Premiere Elements 9 shuts down after edits
          More information needed for someone to help... please click below and provide the requested information
          -Premiere Elements FAQ http://forums.adobe.com/thread/1042180
          By "it shuts down" do you mean ONLY PreElements, or your entire computer?
          If only PreElements, what error message do you receive?
          If your entire computer, read Bill Hunt on BSOD http://forums.adobe.com/thread/772169
          • 2. Re: Premiere Elements 9 shuts down after edits
            3JK Level 1
            Just the program, is says that premiere elements is shutting down, looking
            for a cause of the error and then it just shuts down.  It can trim video
            fine with no problems but when I try to add text to a clip that's when it
            shuts down.
            • 3. Re: Premiere Elements 9 shuts down after edits
              Please go to the FAQ link I posted in reply #1 and answer all of the questions
              What font... and what happens if you use a different font?
              • 4. Re: Premiere Elements 9 shuts down after edits
                A.T. Romano Level 7
                3JK
                Let us go through a routine drill....
                Premiere Elements 9...are you running the program as the 9.0.1 Update?
                Do you have the latest version of QuickTime installed on the computer with Premiere Elements 9.0/9.0.1?
                Are you running the program as Run As Administrator or from a User Account with Administrative Priviledges?
                What is your computer operating system and what do its resources look like?
                What are the properties of the source media that you import to the Timeline? How many of them are on that Timeline when you go to create your titles and the problems begin? What did you set as the project preset based on the properties of those source media?
                Is your video card driver up to date according to the web site of the manufacturer of the video card. If it is, then delete the BadDrivers.txt file whose path in Windows 7 or 8 64 bit is
                Local Disc C
                Program Data
                Adobe
                Premiere Elements
                9.0
                and in the 9.0 Folder is the BadDrivers.txt file that you delete.
                Make sure to be working with Folder Option Show Hidden Files, Folders, and Drives active so that you can see the whole path.
                If that does not work, then try deleting the Adobe Premiere Elements Prefs file found in the Windows 7 or 8 64 bit path
                Local Disc C
                Users
                Owner
                AppData
                Roaming
                Adobe
                Premiere Elements
                9.0
                and in the 9.0 Folder is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then delete the whole 9.0 Folder in which the Adobe Premiere Elements Prefs file exists. Same comment about Folder Option.
                Do you have an installation disc or files for Premiere Elements 9 in case we get to deactivation, uninstall, run of ccleaner, reinstall?
                Please review and then we will see where we are troublehooting wise.
                Thanks.
                ATR
