3 Replies Latest reply on Oct 30, 2013 9:14 AM by Bjoern-DK
    Paid task of modifying script. Who's interested?
    Bjoern-DK
      I have got written permition from Steve Wareham to use his script, and get it modifyed to suit my needs. I offered him to do the job for me, but he asked me to pass it on.
      I don't know anything about scripting, so I would like someone to do the job for me.
      The script is this: http://indesignsecrets.com/free-script-to-change-all-numbers-in-a-document-using-math.php
      It works on InDesign Caracter Styles, but I need it to do the same job on Paragraph Styles too.
      I will pay a reasonable fee for help on this. Please include an estimate on the cost for re-scripting this.
      It needs to work on InDesign CS6 (IE version) and preferable on CC too.
        • 1. Re: Paid task of modifying script. Who's interested?
          Sajeev Sridharan Level 4
          Try this,
          I just changed the search option from character style to paragraph style.
          // numberAdjuster.jsx  Version 1.1.1
                    This InDesign CS3/CS4 JavaScript is intended to perform operations on found numbers. It uses the find/change Grep functions
                    to find numbers within either the entire document, or just the selection. You can select to search for just numbers with
                    a specific character style, and/or a prefix character.
                    This script was written by Steve Wareham at stevewareham.com based on an idea by David Blatner at indesignsecrets.com
          // This function removes non-numeric characters, such as the comma
          function stripNonNumeric(str)
                    str += '';
              var rgx = /^\d|\.|-$/;
               var out = '';
               for( var i = 0; i < str.length; i++ )
                 if( rgx.test( str.charAt(i) ) ){
                   if( !( ( str.charAt(i) == '.' && out.indexOf( '.' ) != -1 ) ||
                          ( str.charAt(i) == '-' && out.length != 0 ) ) ){
                     out += str.charAt(i);
               return out;
          // This function adds commas to numbers
          function addCommas(nStr)
               nStr += '';
               x = nStr.split('.');
               x1 = x[0];
               x2 = x.length > 1 ? '.' + x[1] : '';
               var rgx = /(\d+)(\d{3})/;
               while (rgx.test(x1)) {
                x1 = x1.replace(rgx, '$1' + ',' + '$2');
              return x1 + x2;
          //Function to round numbers
          function numRounder(myNumber, myRoundto)
                    myRoundMod = 1;
                    for(rounding = 0; rounding < myRoundto; rounding++)
                                        myRoundMod = myRoundMod * 10;
                    myRoundedNum = Math.round(myNumber*myRoundMod)/myRoundMod;
          return myRoundedNum;
          //Function to get an array of character style names
          function myGetCharacterStyleNames(){
                    var myStyleNames = app.documents.item(0).paragraphStyles.everyItem().name;
                    return myStyleNames;
          //Check if a preferences file exists, if it does try to read in values
          var thisScript = app.activeScript;
          var myTempFile = new File (thisScript.path +"/" + 'num_adjust_prefs.txt');
          var myTempFileExists = myTempFile.open( 'r', 'TEXT', 'R*ch');
          if (myTempFileExists == true)
                              try //Try to read the temp file
                                        myTempFileContents = myTempFile.read();
                                        myTempFile.close;
                                        myDialogValues = myTempFileContents.split("@,@");
                                        myOperator = parseFloat(myDialogValues[0]);
                                        myOperation = myDialogValues[1];
                                        switch(myOperation)
                                                            case "+":          myOperationIndex = 0                    break;
                                                            case "-":          myOperationIndex = 1                    break;
                                                            case "*":          myOperationIndex = 2                    break;
                                                            case "/" :          myOperationIndex = 3                    break;
                                                            default:           myOperationIndex = 0                    break;
                                        mySearchPrefix = myDialogValues[2];
                                        myCharStyleIndex = parseInt(myDialogValues[3]);
                                        myCharStyleCheck = myDialogValues[4];
                                        if(myCharStyleCheck == "true")
                                                  {myCharStyleCheck = true;}
                                                  else {myCharStyleCheck = false;}
                                        myScopeDocumentRadio = myDialogValues[5];
                                        if(myScopeDocumentRadio == "true")
                                                  {myScopeDocumentRadio = true;}
                                                  else {myScopeDocumentRadio = false;}
                                        myScopeSelectionRadio = myDialogValues[6];
                                        if(myScopeSelectionRadio == "true")
                                                  {myScopeSelectionRadio = true;}
                                                  else {myScopeSelectionRadio = false;}
                                        myScopeStoryRadio = myDialogValues[12];
                                        if(myScopeStoryRadio == "true")
                                                  {myScopeStoryRadio= true;}
                                                  else {myScopeStoryRadio = false;}
                                        myNFASelectionRadio = myDialogValues[7];
                                        if(myNFASelectionRadio == "true")
                                                  {myNFASelectionRadio = true;}
                                                  else {myNFASelectionRadio = false;}
                                        myNFESelectionRadio = myDialogValues[8];
                                        if(myNFESelectionRadio == "true")
                                                  {myNFESelectionRadio = true;}
                                                  else {myNFESelectionRadio = false;}
                                        myRoundtoDefault = parseInt(myDialogValues[9]);
                                        myCustomGrepCheck = myDialogValues[10];
                                        if(myCustomGrepCheck  == "true")
                                                  {myCustomGrepCheck  = true;}
                                                  else {myCustomGrepCheck = false;}
                                        myCustomGrepFieldContents = myDialogValues[11];
                              catch(e)  // If there was an error with reading pref. file
                                                  myOperator = 1;
                                                  myOperationIndex = 0;
                                                  mySearchPrefix ="";
                                                  myCharStyleIndex = 0;
                                                  myRoundtoDefault = 2;
                                                  myCustomGrepFieldContents = "[-]*[0-9][0-9,.]*\\b";
                              } //End of if there is a temp file
                    else{ //Else if the prefs/temp file could not be found
                              myOperator = 1;
                              mySearchPrefix ="";
          //Display dialog box to with options to user
          var myDialog = app.dialogs.add({name:"Number Adjuster 1.1", canCancel:true});
          var myOperations = new Array("Addition", "Subtraction", "Multiplication", "Division");
          var myCharStyles = myGetCharacterStyleNames();
          try{ //try to create the dialog box
                    with(myDialog)
                                        with(dialogColumns.add())
        with(borderPanels.add())
        staticTexts.add({staticLabel:"Perf orm operation on:       "});
        with(mySearchScopeButtons = radiobuttonGroups.add())
        myRadio1 = radiobuttonControls.add({staticLabel:"Entire document", checkedState:myScopeDocumentRadio});
        myRadioStory = radiobuttonControls.add({staticLabel:"Story of selected frame", checkedState:myScopeStoryRadio});
        myRadio2 = radiobuttonControls.add({staticLabel:"Current selection", checkedState:myScopeSelectionRadio});
        staticTexts.add({staticL abel:" "});
        staticTexts.add({staticL abel:"Numbers are formatted as:"});
        with(myNumberFormattButt ons = radiobuttonGroups.add())
        myRadio3 = radiobuttonControls.add({staticLabel:"1,234.56", checkedState:myNFASelectionRadio});
        myRadio4 = radiobuttonControls.add({staticLabel:"1.234,56", checkedState:myNFESelectionRadio});
        staticTexts.add({minWidt h:15});
        staticTexts.add({staticLabel:"Operation to perform:"});
        var myOperationsDropDown = dropdowns.add ({stringList:myOperations, selectedIndex:myOperationIndex });
        staticTexts.add({staticLabel:"Operator: "});
        var myOperatorField = realEditboxes.add({editValue:myOperator});
        staticTexts.add({staticLabel:"How many places to round to?"});
        var myRoundto = realEditboxes.add({editValue:myRoundtoDefault});
        staticTexts.add({minWidth:125});
        staticTexts.add({staticLabel:"Only find numbers with prefix character($,#,etc.): "});
        var myPreCharField = textEditboxes.add({editContents:mySearchPrefix});
        staticTexts.add({minWidth:15});
        var myCharStyleCheckBox = checkboxControls.add();
        myCharStyleCheckBox.checkedState = myCharStyleCheck;
        staticTexts.add({staticLabel:"Only adjust numbers with paragraph style:"});
        var myCharStyleDropDown = dropdowns.add({stringList:myCharStyles, selectedIndex:myCharStyleIndex});
        staticTexts.add({minWidth:25});
        var myCustomGrepCheckBox = checkboxControls.add();
        myCustomGrepCheckBox.checkedState = myCustomGrepCheck;
        staticTexts.add({staticLabel:"Search on Custom RegEx:"});
        var myGrepField = textEditboxes.add({editContents:myCustomGrepFieldContents, minWidth:155});
        staticTexts.add({minWidth:45});
                                        }  // End of the dialog box
                    }//End of try
          catch(e){alert(e + " Try deleting the preferences file");}
          if(myDialog.show() == true)
                              var myRunScript = true; //Key to check if the search and replace funciton should run
                              //Check length of prefix character, it cannot be longer than 1 character
                              var myPrefixcheck = true;
                              if(myPreCharField.editContents.length > 1)
                                                  alert("The search prefix cannot be longer than one character.");
                                                  myRunScript = false;
                               //Set the variables, based on what was entered in the dialog box
                              var myDocument = app.activeDocument;
                              var myNumberFormatIndex = myNumberFormattButtons.selectedButton;
                              var mySearchScopeIndex =mySearchScopeButtons.selectedButton;
                              switch(mySearchScopeIndex)  //Set the scope used to search on
                                                  case 0:          myScope = "doc"                    break;
                                                  case 1:          myScope = "story"                    break;
                                                  case 2:          myScope = "selection"          break;
                                                  default:           myScope = "selection"          break;
                              var myOperator = myOperatorField.editContents; //Change the myOperfield to a realedit box
                              myOperator = parseFloat(myOperator); //this wouldnt be needed
                              var myOperationIndex = myOperationsDropDown.selectedIndex;
                              switch(myOperationIndex)  // Set the operation to perform
                                                  case 0:          myOperation = "+"          break;
                                                  case 1:          myOperation = "-"                    break;
                                                  case 2:          myOperation = "*"          break;
                                                  case 3:          myOperation = "/"                    break;
                                                  default:           myOperation = "+"          break;
                              var myRoundto = parseFloat(myRoundto.editContents);  //change this to a realedit box or combobox
                              //Get the Prefix character if one is being used for search. Escape RegEx reserved chars. if they are being used.
                              var mySearchPrefix = myPreCharField.editContents;
                              if(mySearchPrefix == "$" || mySearchPrefix =="[" || mySearchPrefix =="^" || mySearchPrefix =="." || mySearchPrefix == "|" || mySearchPrefix =="?")
                                        {mySearchPrefix = "\\" + mySearchPrefix;} //Escape special characters search prefixes
                              if(mySearchPrefix == "\\" || mySearchPrefix =="+" || mySearchPrefix == "*" ||mySearchPrefix =="(" || mySearchPrefix == ")")
                                        {mySearchPrefix = "\\" + mySearchPrefix;} //Escape even more special characters search prefixes
                              if(mySearchPrefix != "") // Put the Prefix in [ ] if it is used, create replacePrefix var
                                        {myReplacePrefix = mySearchPrefix; mySearchPrefix = "[" + mySearchPrefix + "]";}
                                        else {myReplacePrefix = mySearchPrefix;}
                              var myCharStyleIndex =myCharStyleDropDown.selectedIndex; // Get character style to search on
                              var myCharStyle = app.documents.item(0).paragraphStyles[myCharStyleIndex];
                              //Set the Grep to search on
                              if (myCustomGrepCheckBox.checkedState == true )
                                        {myGrep = myGrepField.editContents;}
                                        else {myGrep = "[-]*[0-9][0-9,.]*\\b";} //else use this default Grep to search on
                              //Set variables based on which scope to use
                              mySearchScope = new Array();
                              if (myScope == "doc")
                                                  mySearchScope[0] = myDocument;
                                                  mySearchAmount = 1;
                                        else if (myScope == "story")
                                                            if (app.selection.length != 1)
        alert(myErrorMessage = "Select a single text frame and try again");
        else
        mySearchScope[0] = app.selection[0].parentStory;
        mySearchAmount = 1;
                                        else //Else just search on the selection
                                                            mySearchScope = app.selection;
                                                            mySearchAmount = mySearchScope.length;
                                        //Run the search and replace
                                        if (myRunScript == true)
                                                            //For the amount of top level items in the scope (i.e. selections)
                                                            for (i = 0; i < mySearchAmount; i++)
        //Clear the find/change preferences.
        app.findGrepPreferences = NothingEnum.nothing;
        app.changeGrepPreferences = NothingEnum.nothing;
        try //Try to do the search + perform operation + replace
        //Search on character style if that option was checked
        if (myCharStyleCheckBox.checkedState == true )
        {app.findGrepPreferences.appliedParagraphSty le = myCharStyle; }
        //Find matching numbers
        var mySearchGrep = app.findGrepPreferences.findWhat = mySearchPrefix + myGrep; //Find all numbers
        var myFoundArray = mySearchScope[i].findGrep(); //Array of matches to the search grep
        //Change matches to the result of the operation
        for(k = myFoundArray.length - 1; k >= 0; k--)
        var myFoundNumber = myFoundArray[k].contents;
        {myFoundNumber = myFoundArray[k].contents.slice(1);} //Slice of the search prefix if one was used
        if(myNumberFormatIndex == 1) //If the number format is 1.234,56
        //Switch commas with decimals so we can still do some math on found numbers
        myFoundNumber = myFoundNumber.replace(/,/gi, "comma");
        myFoundNumber= myFoundNumber.replace(/\./gi, ",");
        myFoundNumber = myFoundNumber.replace(/comma/gi, ".");
        //Strip Commas from the number
        myStrippedFoundNumber = stripNonNumeric(myFoundNumber);
        //Perform the selected operation on the found number
        if (myOperation == "+"){var myResult =  (parseFloat(myStrippedFoundNumber) + myOperator) + "";}
        else if (myOperation == "-"){var myResult =  (parseFloat(myStrippedFoundNumber) - myOperator) + "";}
        else if (myOperation == "*"){var myResult =  (parseFloat(myStrippedFoundNumber) * myOperator) + "";}
        else if (myOperation == "/"){var myResult =  (parseFloat(myStrippedFoundNumber) / myOperator) + "";}
        //Round the result
        myResult = numRounder(myResult, myRoundto);
        //Add Comma to the result of the operation
        myResult = addCommas(myResult);
        //Switch commas and decimals back to how they were found
        myResult = myResult.replace(/,/gi, "comma");
        myResult = myResult.replace(/\./gi, ",");
        myResult = myResult.replace(/comma/gi, ".");
        //If the search prefix had a "/" added to it to escape reserved regex chars. remove it from the replace prefix
        if(myReplacePrefix.length > 1)
        {myReplacePrefix = myReplacePrefix.slice(1)}
        //Change the found text to the result of the operation
        app.changeGrepPreferences.changeTo = (myReplacePrefix + myResult);
        app.findGrepPreferences.findWhat = (mySearchPrefix + myFoundNumber);
        myFoundArray[k].changeGrep();
        } //End of looping through all found matches, performing operation, and replacing with the result
        } //End of try
        catch(e){alert(e)}
        //Reset Grep Preferences
        } //End of looping through all top level objects
                                                  } //End of if myRunScript is true
                              //Write new values from dialog box into temp file
                              try
                                                  var myTempFileContents = myOperator + "@,@" + myOperation + "@,@" + myPreCharField.editContents + "@,@" + myCharStyleDropDown.selectedIndex + "@,@" + myCharStyleCheckBox.checkedState + "@,@" + myRadio1.checkedState + "@,@" + myRadio2.checkedState + "@,@" + myRadio3.checkedState + "@,@" + myRadio4.checkedState + "@,@" + myRoundto + "@,@" + myCustomGrepCheckBox.checkedState + "@,@" + myGrepField.editContents + "@,@" + myRadioStory.checkedState + "@,@";
                                                  myTempFile.open( 'w', 'TEXT', 'R*ch');
                                                  myTempFile.writeln(myTempFileContents);
                                                  myTempFile.close();
                                        catch(e){alert(e);}
                              }//end of if dialog is not canceled
          //End of numberAdjuster.jsx
          Vandy
          • 2. Re: Paid task of modifying script. Who's interested?
            Bjoern-DK Level 1
            Whow - that was fast!
            I got an error before reaching the dialog box:
            • 3. Re: Paid task of modifying script. Who's interested?
              Bjoern-DK Level 1
              Update:
              I found out, that the linebreaks in the forum thread inserted a space in the text.
              I removed those spaces, and it works!
              Next wish:
              How difficult is it to modify the "Perform operation on" to include a page range?
              ie: From page ____ to page ____ .
