0 Replies Latest reply on Oct 30, 2013 6:30 AM by brentsmith
    Device Fonts such as Wingdings
    brentsmith
      Hello,
      I'm trying to get a user's device fonts to be applied to Closed Captions to meet an upcoming FCC requirement. I'm able to use Font.enumerateFonts(true) to get a list of fonts on the device but once I have this list of font I'm unable to use it. As an example I was trying to use Wingdings, which I have on my device but when I set it using StyleSheet or FontFormat the font was falling back to one of the base fonts.
      I noticed that the YouTube Captions (in flash only) allow a user to select a font on their system and it seems to work (I tried it with Wingdings and several obscure fonts I have locally). After much googling and testing I've been unable to come up with a good way to do this. Is there something you can recommend I try?
      Here's an example (remove the "W" conditional to see most device fonts render):
      private function onAddedToStage(e:Event):void{
           var offset:Number = 0;
           var fonts:Array = Font.enumerateFonts(true);
        for each(var font:Font in fonts)
                if (font.fontName.charAt(0) == "W")
                     var myText:TextField = new TextField();
            myText.y += offset;
                    myText.width = 600;
                     var myFormat:TextFormat = new TextFormat();
                     myFormat.size = 7;
                     myFormat.align = TextFormatAlign.LEFT;
                     myFormat.font = font.fontName;
                     myText.defaultTextFormat = myFormat;
                     myText.text = font.fontName;
                     myText.embedFonts = false;
                     offset += 10;
                     addChild(myText);
      Any help would be appreciated,
      Brent
