5 Replies Latest reply on Oct 30, 2013 9:35 PM by A.T. Romano
    Is there a "File menu" in PE 11?
    timprosser
      I got PE 11 quite a few months ago and struggled with it mightily, then gave up for a month or two, then tried again, etc., so I'm still a novice.  I keep reading forum entries and help information that refer to a File menu like I see in most other programs, but PE 11 doesn't have one that I can see and I'm tired of googling for answers and getting nowhere.
      Lately I've finally started to have some success with the program, mostly since finding a table of file menu entries with keyboard shortcuts at http://atr935.blogspot.com/2013/09/pe11-keyboard-shortcuts.html.  Still there are many commands I can't access with hot keys.
      Is there something wrong with my install?  Is there a special hot key or something else that will open such a menu?
        • 1. Re: Is there a "File menu" in PE 11?
          A.T. Romano Level 7
          timprosser
          What computer operating system is your Premiere Elements 11 running on?
          Are you opening the program from the Welcome Screen or bypassing it to get to the Premiere Elements 11 workspace.
          The following is the Premiere Elements 11 Expert workspace that you should be seeing
          Are you getting the lineup of menus are the top of the Expert workspace as shown in the above screenshot?
          File Menu
          Edit Menu
          Clip Menu
          Timeline Menu
          Text Menu
          Action Bar Menu
          Tools Menu
          Window Menu
          Help Menu
          Let us start here. If your Premiere Elements 11 Windows Expert workspace looks differently than the screenshot posted, could you post a screenshot of what you are seeing instead.
          Thanks.
          ATR
          • 3. Re: Is there a "File menu" in PE 11?
            timprosser Level 1
            Thanks - I'll have to dig into those tutorials and other pages, almost all of which I hadn't found yet.  Your image clearly shows the menus I'd expect, but mine does not have that top row and I didn't know if it was supposed to be there or if there was some way to hide it that I could turn off.  I've never seen it. zz in any case - here's what I see every time.PE11 screen.jpg
            • 4. Re: Is there a "File menu" in PE 11?
              timprosser Level 1
              Incidentally, I'm running Windows 7 32 bit on an old Dell XPS laptop with 2 gb of RAM.  I'm still wondering if I have a bad install, or if there is some way that the menu bar has been turned off in my copy.
              • 5. Re: Is there a "File menu" in PE 11?
                A.T. Romano Level 7
                timprosser
                Has your computer Taskbar always been at the top of Window 7 32 bit Window? That caught my attention first thing.
                http://www.howtogeek.com/howto/9440/move-the-taskbar-to-different-locations-in-windows/
                What is the native resolution of your computer monitor and what is the display actually set at.
                Another consideration is your level of computer resources. Much too low for your video editing plans especially if you go beyond SD.
                Premiere Elements 11 on Windows 7 32 bit is a 32 bit application with all the limitations of a 32 bit system which includes  maximum supported installed RAM 4 GB with 3 GB or less of that available. And, you only have 2 GB RAM installed to start with. To take advantage of Premiere Elements11, it should be running on Windows 7 or 8 64 bit with at least 4 GB installed RAM, preferably 8 GB.
                But, for now, my prime candidate for those missing menus is display settings for your computer monitor.
                Also, make sure that you have the latest version of your video card driver installed according to the web site of the manufacturer of the video card. By any chance are you running Windows 7 with a High Contrast Theme?
                Please review the above and then we will see if we can sort out the factors resulting in the missing menus.
                Depending on your answers to the above and your troubleshooting, a program deactivation, uninstall, ccleaner run through, reinstall may be in order. Do you have an installation disc for the program?
                More later.
                ATR
