11 Replies Latest reply on Nov 1, 2013 9:07 AM by resdesign
    JS error using JQuery Columnizer Plugin
    ladobeugm Level 1
      I'm not sure how many of you are familiar with this plugin for JQuery, but Columnizer (http://welcome.totheinter.net/columnizer-jquery-plugin/) is a plugin that allows you to create multi column text from one div. I know that can now be done CSS3, but this script works in IE, which is very important.
      Problem is getting it to work in Edge. I've tried a number of different methods to make it work and I'm enclosing a simple example .zip file on Dropbox I'll share in just a moment.
      Basically, I have a text field on stage with the name 'copy'. So I call columnizer by the following in my compositionReady:
      sym.$('copy').columnize({columns:2});
      Simple, right? Only I get a JS error (Javascript error in event handler! Event Type = element) in console and while the text renders, I don't get my two columns laid out.
      I've tried it on the stage, from a click event, using different ways in my code to access the field, all to no avail. Is there a conflict between Columnizer and Animate? Should be able to accept it.
      Here's my files: https://www.dropbox.com/s/1h0s6hf5djkyvus/columizer.zip
      Any help would greatly be appreciated.
