0 Replies Latest reply on Nov 1, 2013 4:49 AM by Jonathan Scherrer
    Problems getting FileProvider and ContentProviders working in Flex Native Extensions.
    Jonathan Scherrer
      As part of an Adobe Flex application, I am writing an android native extension to allow me to send emails with file attachments using files generated from flex code. However I don't want the file to be world readable as it might contain sensitive data. Therefore I want to send the file from within my app's internal storage area / cache. I am using Intents to communicate with other apps (such as Gmail) to send the email.
      After doing some research, I discovered that the functionality of FileProviders should do exactly what I want. However the static method **FileProvider.getUriForFile()** is silently failing / crashing the native extension. The native extension stops and returns null with no errors or output from LogCat.
      If I manually create the Uri by parsing a string, Gmail complains that it can't attach the file to the email, and the email is sent with no attachment.
      Code in FREObject call():
          //... (Deal with params from flex app) ...
          //Setup Intent, and attach email data send from flex application:
          Intent intent = new Intent(Intent.ACTION_SEND);
          intent.setType("message/rfc822");
          intent.putExtra(Intent.EXTRA_EMAIL, toArray);
          intent.putExtra(Intent.EXTRA_CC, ccArray);
          intent.putExtra(Intent.EXTRA_BCC, bccArray);
          intent.putExtra(Intent.EXTRA_SUBJECT, subject);
          intent.putExtra(Intent.EXTRA_TEXT, message);
          Log.d("emaildebug", filePath);
          //Check we can read our email attachment from flex app
          //filePath is a temporary cache location.
          File appFile = new File(filePath);
          if (appFile.exists() && appFile.canRead()) {
              Log.d("emaildebug", "file successfully read");
          } else {
              return null;
          //Get a handle on the android Context instead of FREContext.
          Context androidContext = (Context) context.getActivity();
          //Get the location of the root files directory.
          File attachPath = androidContext.getFilesDir();
          File attachFile = new File(attachPath, "attachment.pdf");
          //Copy file to root of files directory, so that our FileProvider can access it.
          try {
              copyFileUsingChannel(appFile, attachFile);
          } catch (Exception e) {
              Log.d("emaildebug", e.getMessage());
          Log.d("emaildebug", "attachFile exists: " + attachFile.exists() );
          Log.d("emaildebug", "attachFile path: " + attachFile.getAbsolutePath());
          //This line will silently crash the native extension, instantly returning null, even in try catch.
          //Uri contentUri = FileProvider.getUriForFile(androidContext, "com.example.androidextensiontest.provider", attachFile);
          //Therefore manually create the Uri from a string.
          Uri contentUri = Uri.parse("content://com.example.androidextensiontest.provider/files/attachment.pdf");
          Log.d("emaildebug", "uri created");
          Log.d("emaildebug", contentUri.toString());
          //Grant permisions for all apps that can handle given intent
          //Courtesy of: http://stackoverflow.com/questions/18249007/how-to-use-support-fileprovider-for-sharing-co ntent-to-other-apps
          List<ResolveInfo> resInfoList = androidContext.getPackageManager().queryIntentActivities(intent, PackageManager.MATCH_DEFAULT_ONLY);
          for (ResolveInfo resolveInfo : resInfoList) {
              String packageName = resolveInfo.activityInfo.packageName;
              Log.d("emaildebug", "package: " + packageName);
              androidContext.grantUriPermission(packageName, contentUri, Intent.FLAG_GRANT_WRITE_URI_PERMISSION | Intent.FLAG_GRANT_READ_URI_PERMISSION);
          intent.setFlags(Intent.FLAG_GRANT_READ_URI_PERMISSION | Intent.FLAG_GRANT_READ_URI_PERMISSION);
          intent.putExtra(Intent.EXTRA_STREAM, contentUri);
          context.getActivity().startActivity(Intent.createChooser(intent, "Send mail using..."));
      In Manifest File:
          <provider
              android:name="android.support.v4.content.FileProvider"
              android:authorities="com.example.androidextensiontest.provider"
              android:exported="false"
              android:grantUriPermissions="true" >
              <meta-data
                  android:name="android.support.FILE_PROVIDER_PATHS"
                  android:resource="@xml/my_paths" />
          </provider>
      **In my_paths.xml:**
          <paths xmlns:android="http://schemas.android.com/apk/res/android">
              <files-path name="files" path="." />
          </paths>
      LogCat output:
          11-01 10:58:09.971: D/emaildebug(17013): /data/data/air.com.example.MyAppName.debug/cache/FlashTmp.V17013/attachment.pdf
          11-01 10:58:09.971: D/emaildebug(17013): file successfully read
          11-01 10:58:09.991: D/emaildebug(17013): attachFile exists: true
          11-01 10:58:09.991: D/emaildebug(17013): attachFile path: /data/data/air.com.example.MyAppName.debug/files/attachment.pdf
          11-01 10:58:09.991: D/emaildebug(17013): uri created
          11-01 10:58:09.991: D/emaildebug(17013): content://com.example.androidextensiontest.provider/files/attachment.pdf
          11-01 10:58:09.991: D/emaildebug(17013): package: com.android.email
          11-01 10:58:09.991: D/emaildebug(17013): package: com.google.android.gm
      If I attempt to send the file from external storage using a file:// Uri, the file attachment works perfectly. However as previously mentioned the file attachment potentially contains sensitive data, therefore I wish to avoid using external storage.
      What I believe I'm seeing is that FileProviders do not work within native extensions. I tried also using a ContentProvider, however neither the Constructor nor onCreate methods were called.
      ContentProvider Manifest:
          <provider
              android:name="com.example.androidextensiontest.provider.MyContentProvider"
              android:authorities="com.example.androidextensiontest.provider">
          </provider>
      MyContentProvider:
          public class MyContentProvider extends ContentProvider implements PipeDataWriter<InputStream> {
          public MyContentProvider() {
              // Never Output
              Log.d("emaildebug", "Constructor");
          @Override
          public boolean onCreate() {
              // Never Output
              Log.d("emaildebug", "OnCreate");
              return false;
          //.. Rest of class
      Am I doing something wrong or are ContentProviders / FileProviders just not supported within flex native extensions? Alternatively, are there any other solutions for attaching a file located in internal storage to an email. My searching on Stack Overflow and google has not encountered anyone else having similar experiences, especially regarding FileProvider.getUriForFile(). Any help / comments appreciated.
      Sorry for the wall of text, I wanted to record everything I've tried so far, and what works and what doesn't.
      tldr; Do ContentProviders / File Providers work in flex native extensions? Are there any other methods of sending internal files as email attachments?
