4 Replies Latest reply on Dec 20, 2007 2:37 PM by LukasCanoe
    how do you reference an attached movie?
    gbowhall
      Hello:
      I am having some difficulty referencing a dynamically created attached movie (attached_popUp) created from the popUp_hitArea movie clip. It cannot seem to find its way into the attached movie? I have run a trace(this) from inside the attached movie to confirm the linking name...
      THIS DOES NOT RETURN A TRACE STATEMENT:
      _level0.popUp_hitArea.attached_popUp.onRollOver=function(){
      trace("testing");
      THIS DOES RETURN A TRACE STATEMENT:
      _level0.popUp_hitArea.onRollOver=function(){
      trace("testing");
      THIS IS WHAT I USED TO ATTACH THE MOVIE IN THE FIRST PLACE:
      _level0.roll_A_hotspot.onRelease=function(){
      popUp_hitArea.attachMovie("popUp_ID", "attached_popUp", 1);
      This seems like this must be something obvious?!? Any help would be greatly appreciated.
      Thank you!
      - Garrett
        • 1. Re: how do you reference an attached movie?
          dr_ross Level 1
          First step is to ask is the attachedMovie actually visible? if its not it could be due to using 1 as the depth in attachMovie, use getNextHighestDepth() instead,
          depending on how all this code is scoped, you might need to prefix your attach with _level0
          _level0.popUp_hitArea.attachMovie("popUp_ID", "attached_popUp", _level0.popUp_hitArea.getNextHighestDepth());
          If its visible then you could iterate through all the objects in _level0.popUp_hitArea and find out whats inside with
          for(var obj in _level0.popUp_hitArea)
          trace("Found "+obj+":"+_level0.popUp_hitArea[obj]);
          Otherthan using the evil _level0 prefix it looks alright
          • 2. Re: how do you reference an attached movie?
            LukasCanoe Level 1
            You need to use _root["popUp_hitArea"] or eval("popUp_hitArea") to reference the attached movie. so it might go like this :
            _root["popUp_hitArea"].onRollOver=function(){
            trace("testing");
            hope this helps
            MattCanoe
            • 3. Re: how do you reference an attached movie?
              dr_ross Level 1
              that really won't do anything different, _root["popUp_hitArea"] is the same as writing _root.popUp_hitArea as you're just concating a straight string to reference the movie by name.
              You'd use that to reference and object with dynamic referencing
              i.e.
              for(var i=0;i<10;i++)
              this["myMovie_"+i]._x = 200;
              instead of
              this.myMovie_0._x = 200;
              this.myMovie_1._x = 200;
              this.myMovie_2._x = 200;
              this.myMovie_3._x = 200;
              this.myMovie_4._x = 200;
              etc
              • 4. how do you reference an attached movie?
                LukasCanoe Level 1
                Well if you say so(dr_ross), but I have done it that way many times to reference an attached movie and it seems to work fine. Although I think I should have had it access the name he set it to when he attached it, which would be _root["attached_popUp"] can't remember exactly.
