1. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Trevor.Dennis Nov 1, 2013 2:46 PM (in response to tudor)1 person found this helpfulI haven't read the tutorial, but this should work.
Turn off the background layer
Select all the layers > right click > and make into a Smart object.
Ctrl (Cmd) click the Smart Object's icon to load it as a selection, and add a layer mask.
The background will become transparent.
2. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
tudor Nov 1, 2013 3:32 PM (in response to Trevor.Dennis)Hi Trevor, thanks for your reply. There actually isn't a background image, the tutorial uses a font raster which it fills with white, then solarizes, so the effect is built onto it's own background not as a separate layer. I tried what you said but the effect is all rimmed with black so I can't use it on any other backgrounds then black on the web. Thanks for the help though.
3. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
thatdesignkid Nov 1, 2013 4:20 PM (in response to tudor)Hi tudor,
Try this: hide the gradient layer for now. Now make a new layer and put it over the text stuff. Set the blending mode to something like color dodge or something like that. You can scroll through them until it looks right, and then it might work to delete the backgrou layer. This makes it so that you're working off of a normal layer with blending modes instead of bothering with adjustment layers (don't get me wrong, adjustment layers are truly magical things, but sometimes their magic can backfire in a case like this ) If you're still having the same problem, try alt-clicking right between the two layers. This will make the gradient a clipping mask of the text, which is pretty much a layer mask in the exact shape of the text layer. Should work. If you don't understand (I don't know how to explain this very well haha), this link should show you the alt-click thing: http://www.shutterstock.com/blog/2010/04/using-a-clipping-mask-in-photoshop-fast-and-easy/
Happy Photoshopping!
4. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Chuck Uebele Nov 1, 2013 5:05 PM (in response to thatdesignkid)1 person found this helpfulWith just the burst showing, ctrl-click on that layer's icon to load it into a selection. Create a new layer and fill it with white using the selection. This works far better than trying to create a mask, as the layer is pure white with no fringing. You can put this over any bg.
5. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
tudor Nov 1, 2013 6:05 PM (in response to Chuck Uebele)Hi, ctrl-click any of the layers selects the entire canvas, I think if there was an alternative way to do the fill and solarize of the raster text in the tutorial then this wouldn't happen, but I don't know how enough to work around these steps to creating this effect
6. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Chuck Uebele Nov 1, 2013 6:20 PM (in response to tudor)1 person found this helpfulYou're, right, ctrl click on the the RGB channel. That will give you the selection you need.
7. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Trevor.Dennis Nov 1, 2013 8:17 PM (in response to Chuck Uebele)csuebele wrote:
Great idea. It was worth getting up today just to learn that tip.
9. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Trevor.Dennis Nov 1, 2013 8:34 PM (in response to Trevor.Dennis)It's a nice tutorial, but have a hunt round for a brush set called Sparkle_N.abr or it might be called 'Stars & Sparkles'. The set contains a sharp starburst very like the effect in the tutorial. I like brushes because they are so quick and versatile, and just about any subject you can think of is covered by an existing brush set. Or if not, it is so easy to create your own.
10. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Trevor.Dennis Nov 1, 2013 8:35 PM (in response to Trevor.Dennis)Very nice graphics Jack. Yours?
11. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Chuck Uebele Nov 1, 2013 8:38 PM (in response to Trevor.Dennis)Yes, that's mine.
12. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
tudor Nov 2, 2013 12:15 PM (in response to Chuck Uebele)Hi, I see what that does, but it only gives me a very small so I held down shift and ctrl and keep clicking and it slowly began selecting it all, now I've got the entire layer selected all the way to the tips of the light flares, I'll still have to usea black background under the image, but at least I don't have a solid black background now, can add stars etc. I tried a bunch of different steps throughout the tutorial but couldn't get it to work without filling it with white and then solarizing. Thanks for your help it is by far better than what I had.
13. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
tudor Nov 2, 2013 12:18 PM (in response to Chuck Uebele)But you're sun rays turned out great using this technique... makes me want to keep trying. Is it because they are less jagged. If you think of any other solutions and/or have the time I'd love to know them. Thanks again
14. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Chuck Uebele Nov 2, 2013 12:22 PM (in response to tudor)Don't be fooled by the ant lines. They really don't tell you what is selected. You don't want the entire layer selected! If the white area is weak. you can duplicate the layer and apply screen mode to the layer on top to brighten it. You should only have to ctrl-click once on the channel to get your selection. Once you have your slection and are ready to fill the blank layer, you can fill it several times to build up the density or duplicate the layer a couple time to build up the density. Yes, you'll need a black background or some other bg when you're done.
15. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
tudor Nov 2, 2013 12:43 PM (in response to Chuck Uebele)Hi, I understand what you mean and will definitely play with the density, but I don't understand how the the antilines are more then they appear in the one ctrl click. This is definitely the answer I've given you full credit and helpfuls along the way.
This is what I got with one ctrl click
This is what I get with a lot of ctrl-shift clicks
So now after using this or another version using less clicks to find out how the anti-lines work a bit better, I'd just add a mask to clear out the background.
16. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Trevor.Dennis Nov 2, 2013 2:14 PM (in response to tudor)1 person found this helpfulHave you tried diferent Blend modes? Lighten would show the flames, but none of the black, so it would depend what lies under the graphic as to what will and won't show. But other Blend modes in the Lighten group might work as well.
I think the marching Ants indicate =>50% selection. If you use one of the selection methods above, you can use the Mask Properties panel to fine tune the Layer mask, which I would expect to enable you to achieve a pretty good efect minus the black fringe. Without reading the tutorial, I would also expect to 'adapt' it to have a non-black fringe. These things are just guides afterall, and you should try to think about how they work, and what each step is doing. That builds your PS skills and you'l be a PS master before you know it.
17. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Chuck Uebele Nov 3, 2013 6:26 AM (in response to Trevor.Dennis)Yes, Trevor is correct about the antlines. They are only an average of the selection. There are lots of ways to create burst effects like this. You could smooth out the jagged lines with a slight radial blur. The only problem with it is that you either have to have what you want to blur perfectly centered in you document, or attempt to guess where the center is in the very small dialog box. With the above image, I use the angle gradient tool set to noise. This give a wild multcolored gradient, which I then converted to B&W, adjusted the contrast, put in screen mode, and manually masked the areas I wanted.
18. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
tudor Nov 3, 2013 4:48 PM (in response to Chuck Uebele)Thanks so much for the help, I had no idea I'd learn so much relating to this one tutorial. Using all of the above I seem to be able to isolate all the layers using masks and I've played with the blend modes. I had most of them set to screen so each visible layer added itself to the entire look, a sequence of 5 layers. I had one more questions, but I'm not sure how this forum works so I posted it in a second section since I thought it built more off the results of this question (for only one layer) then related to the original question - http://forums.adobe.com/message/5809842#5809842. Either way, thanks so much again for all your help, this was a lot of fun!
19. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Trevor.Dennis Nov 3, 2013 1:42 PM (in response to Chuck Uebele)csuebele wrote:
Jack you have some great workflow ideas. Using the gradient tool that way was new to me, but what a great tool to have in your virtual Photoshop toolbox. I had to hunt for how to set the Angle gradient to noise, but these two links did the trick for me:
http://www.webdesignerdepot.com/2010/07/exploring-photoshop%E2%80%99s-angle-gradient-tool/
http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e41001031ab64-77e1a.h tml
(Click on create noise gradients or scroll to the bottom of the screen).
20. Re: How would you do this "star burst" tutorial but have transparent backgrounds when you're finished
Chuck Uebele Nov 3, 2013 8:24 PM (in response to Trevor.Dennis)Thanks, Trevor and Tudor. Glad I could be of help.
