5 Replies Latest reply on Dec 20, 2007 12:35 PM by k0nG86
    Removing Items From Array Collection
    k0nG86
      Hi. I have an array collection which is made up of items defined in class PlayListEntry. I want to remove all the items that have the value of property select set to false. This is what i have come up with, it works fine, but only removes half the items at a time. I think this is because when you remove and item with removeitemat() it shifts the index of the items. How can i get around this?
      Code
      private function removeitems():void{
      for each (var ple:PlayListEntry in songCollection){
      if (ple["select"] != true){
      songCollection.removeItemAt(songCollection.getItemIndex(ple));
        • 1. Re: Removing Items From Array Collection
          Garyl Woolworth Level 1
          Here's a sample application I wrote that achieves what you're looking for.
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          [Bindable] private var medalsAC:ArrayCollection = new ArrayCollection([
          {Country:"USA", Gold:35, Silver:39, Bronze:29, select:true},
          {Country:"China", Gold:32, Silver:17, Bronze:14, select:true},
          {Country:"Russia", Gold:27, Silver:27, Bronze:38, select:true},
          {Country:"USA2", Gold:35, Silver:39, Bronze:29, select:false},
          {Country:"China2", Gold:32, Silver:17, Bronze:14, select:false},
          {Country:"Russia2", Gold:27, Silver:27, Bronze:38, select:false},
          {Country:"USA3", Gold:35, Silver:39, Bronze:29, select:true},
          {Country:"China3", Gold:32, Silver:17, Bronze:14, select:true},
          {Country:"Russia3", Gold:27, Silver:27, Bronze:38, select:true}
          private function filterItems():void {
          for(var i:Number = 0; i < medalsAC.length; i++){
          if(medalsAC .select == false){
          // => Remove item
          medalsAC.removeItemAt(i);
          // => Refresh collection so it see's new change.
          medalsAC.refresh();
          // => Start at beginning and keep looking
          i = 0;
          </mx:Script>
          <mx:Button x="10" y="10" label="Remove False Items" click="filterItems()"/>
          <mx:DataGrid left="10" right="10" top="35" bottom="10" dataProvider="{medalsAC}">
          <mx:columns>
          <mx:DataGridColumn headerText="Country" dataField="Country"/>
          <mx:DataGridColumn headerText="Gold" dataField="Gold"/>
          <mx:DataGridColumn headerText="Silver" dataField="Silver"/>
          <mx:DataGridColumn headerText="Bronze" dataField="Bronze"/>
          <mx:DataGridColumn headerText="Select" dataField="select"/>
          </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          • 2. Re: Removing Items From Array Collection
            k0nG86 Level 1
            I was so close to this earlier. I just wasn't reseting i to 0. Only problem i've got now is that i can't seem to reference select. The array collection is built in an external class... any suggestions? It wont work as songCollections.song as you suggested.
            Thanks so much for your help.
            • 3. Re: Removing Items From Array Collection
              Is the array collection songCollection within the class set as public? You should be able to do PlayListEntry.songCollection .song if it's public. Or you could have a method within PlayListEntry that returns the songCollection so you could have a collection outside of the class that has the same data. Something like this.
              var songs:ArrayCollection = PlayListEntry.getSongCollection();
              and inside of PlayListEntry you would have
              public function getSongCollection():ArrayCollection {
              return songCollection;
              Without seeing more of your code of how your using it I'm not sure how I can better help you. Hope this helps though.
              • 4. Removing Items From Array Collection
                For whatever reason the post didn't copy my code completely. Within the function of filterItems() it doesn't have the after medalsAC the line should read if(medalsAC[ i ].select == false){
                • 5. Re: Removing Items From Array Collection
                  k0nG86 Level 1
                  Perfect! that works a treat. Much thanks!
