1 Reply Latest reply on Nov 4, 2013 11:14 AM by A.T. Romano
    Adding text
    AZ Aurora Level 1
      I have added text to several projects before however this time around when I am in sceneline and add text to an image it appears on the image that I want it and than also shows up on the next image. If I delete it from the second image it also deletes it from the first image (the one that I want it on). What am I doing wrong this time around? Thanks
        • 1. Re: Adding text
          A.T. Romano Level 7
          AuroraAz
          Please double click your workflow.
          For now, I am assuming that you are still with Premiere Elements 9.0/9.0.1 and are in the Sceneline workspace.
          If you want to have a title over one of your images in one of the spaces in the Filmstrip, are you clicking on that space to get a blue outline around it? After that, Title Menu/New Title/Default Text. After that, type and click Done. There should be one title, and that title should be for the Filmstrip space that you selected.
          When you go to delete that title, if you are not already, go to Organize/Project area, right click the title file, and then click Clear.
          It should be a straight forward route.
          Please double check and then let us know the outcome.
          Thanks.
          ATR
