2 Replies Latest reply on Nov 4, 2013 2:38 PM by aoswood
    Changing Object Style
    aoswood
      I have a script that adds a stroke around the piece, that is a spot color called Dieline. It works great except if the supplied file has a Object Style defined. The box it creates has that style applied to it. I would like to change the Object style to "None" but am having troubles figuring out how to accomlish this.
      Any help would be greatly appriecatated.
      //Script to create dieline at page size
      main();
      function main(){
          var myDocument = app.activeDocument;
          var myDielineColor = getOrAddColor(myDocument, "Dieline", ColorModel.spot, [100, 0, 0, 0])
          var myNoneSwatch = myDocument.swatches.itemByName("None");
          createLayer(myDocument, "Dieline");
          for (x=0;  x < app.activeDocument.pages.length ; x++) {
              myPage = app.activeDocument.pages[x]
              var myCoord = myPage.bounds;
              //Create the rectangle and move it to the Dieline layer
              var myRect = myPage.rectangles.add({fillColor:myNoneSwatch, strokeColor:myDielineColor, geometricBounds:(myCoord)});
              myRect.itemLayer = myDocument.layers.itemByName("Dieline");
      function createLayer(myDocument, myLayer){
           if(!myDocument.layers.item(myLayer).isValid){
               myDocument.layers.add({name:myLayer})
               .move(LocationOptions.AT_BEGINNING)
      function getOrAddColor(myDocument, myColorName, myColorModel, myColorValue){
                if(!myDocument.colors.item(myColorName).isValid){
              var myColor = myDocument.colors.add();
              myColor.name = myColorName;
              myColor.model = myColorModel;
              myColor.colorValue = myColorValue;
           else {
              var myColor = myDocument.colors.itemByName(myColorName);
          return myColor
        • 1. Re: Changing Object Style
          Jump_Over Level 5
          Do it in two separate steps:
          1. apply objectStyle "None"
          2. apply your properties
          so inside your loop:
          var myRect = myPage.rectangles.add( { appliedObjectStyle: myDocument.objectStyles.item(0) } );
          myRect.properties = {
               geometricBounds: myCoord
          Jarek
          • 2. Re: Changing Object Style
            aoswood Level 1
            Thanks a bunch I was trying to do it all in one step and was banging my head against the wall. This makes sense.
