0 Replies Latest reply on Nov 5, 2013 1:01 AM by jasonzhuang
    Disable auto adjust selectIndex after ArrayCollection refresh()
    jasonzhuang Level 1
      When user click one item in the list and remove it, the list will auto adjust current selectIndex and caretIndex even set selectedIndex = -1. Since user already remove the item, I want the list select no item and not focus on anyItem. If in the removeLast() comments "lastItem.digit = -100; _dataProvider.refresh()", it will works fine.
      Before remove "43" item:
      After remove the "43" item, auto select first item(I want the list has no selected item and no caret item):
      Here is the code:
      //===========main==================
      <s:Application
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx"
          xmlns:components="components.*"
          creationComplete="generateList()"
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.collections.ISort;
                  import mx.collections.Sort;
                  import mx.events.FlexEvent;
                  import spark.events.IndexChangeEvent;
                  [Bindable]
                  private var _dataProvider:ArrayCollection;
                  private function sortOnDigit(item0:Object, item1:Object, fields:Array = null):int {
                      var value:int = int(item0.digit) - int(item1.digit);
                      return value > 0? 1 :value< 0 ? -1 :0;
                  private function generateList():void {
                      var items:Array = [];
                      for (var i:int = 0; i<5; i++) {
                          var digit:int = Math.floor(Math.random()*100);
                          items.push(digit);
                      _dataProvider = new ArrayCollection(items);
                      var sort:ISort = new Sort();
                      sort.compareFunction = sortOnDigit;
                      _dataProvider.sort = sort;
                      _dataProvider.refresh();
                  private function removeLast():void {
                      var lastItem:Object = _dataProvider.getItemAt(_dataProvider.length -1);
                      // Note: MUST refresh
                      _dataProvider.removeItemAt(_dataProvider.getItemIndex(lastItem));
                      // =========== NOT WORK ================//
                      list.selectedIndices = new Vector.<int>();
                      list.selectedIndex = -1;
          </fx:Script>
          <s:layout>
              <s:VerticalLayout horizontalAlign="center"/>
          </s:layout>
          <s:List
              id="list"
              change="selectChange()"
              borderColor="#000000"
              contentBackgroundColor="#cccccc"
              requireSelection="false"
              dataProvider="{_dataProvider}"
              allowMultipleSelection="true"
              itemRenderer="components.DemoItemRenderer"
              <s:layout>
                  <s:VerticalLayout paddingLeft="10" paddingRight="10"/>
              </s:layout>
          </s:List>
          <s:Button label="Remove Item" click="removeLast()"/>
      </s:Application>
      // =============compomemts.DemoItemRenderer================//
      <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                      width="50" height="100"
                      autoDrawBackground="false"
          <s:states>
              <s:State name="normal" />
              <s:State name="hovered" />
              <s:State name="selected" />
              <s:State name="dragging"/>
              <s:State name="normalAndShowsCaret" stateGroups="caret" />
              <s:State name="hoveredAndShowsCaret" stateGroups="caret" />
              <s:State name="selectedAndShowsCaret" stateGroups="caret" />
          </s:states>
          <fx:Script>
              <![CDATA[
                  override public function set data(value:Object):void {
                      super.data = value;
                      if (data == null){
                          return;
                      txt.text = String(data.digit);
          </fx:Script>
          <!--selected: red, selectedAndShowsCaret: blue, hovered: yellow-->
          <s:Rect width="100%" height="100%" includeIn="selected, selectedAndShowsCaret">
              <s:fill>
                  <s:SolidColor color.selected="#ff0000" color.selectedAndShowsCaret="#00ffff"/>
              </s:fill>
          </s:Rect>
          <s:Rect width="100%" height="100%" includeIn="hovered">
              <s:fill>
                  <s:SolidColor color="#ffff00"/>
              </s:fill>
          </s:Rect>
          <s:Label color="#000000" id="txt" horizontalCenter="0" verticalCenter="0" visible.dragging="false"/>
      </s:ItemRenderer>
