1 Reply Latest reply on Nov 5, 2013 8:26 AM by SAFEHARBOR11
    Distorted video after export
      I have exported a video using AVCHD mp4 format. 25 fps. 1280x720 px. Aspect "Square Pixels(1.0) 1:1. Both tried CBR and VBR. With target bitrate 1.6 Mbps. See the attached pic for settings. And also see the distorted video problem I have. Can you please help me with correcting the export settings? Thanks.
        • 1. Re: Distorted video after export
          SAFEHARBOR11 Most Valuable Participant
          The image of the lady shows interlace artifacting and that doesn't make sense since the export was progressive and that should deinterlace the footage. One thing to check, I see that Aspect Ratio is set to "Custom", this ought to be 16:9 so please try that. Also just noticed "TV Standard" is set to "NTSC", should be "PAL" for 25fps video.
          Perhaps you should take a step back. What is the intended delivery format? There are a ton of H.264 presets and most of them willl yield good results. You have everything customized and that is likely the issue. I would start with a decent preset and see what that does before you change things around.
          Jeff Pulera
          Safe Harbor Computers
