8 Replies Latest reply on May 1, 2017 7:37 AM by suzan@wardend.com
    Where is ScriptingListenerJS.log?
    boo radley 2013 Level 3
      Hi guys
      I've upgraded to Win7 64-bit and seem to have lost track of where PhotoshopCS6 places the ScriptingListenerJS.log file.
      On my old WinXP, this file was automatically placed on the desktop, but in Win7, it's no longer there.
      So far, these are the steps I've taken to get the file back on my Win7 desktop:
      1. copied the folder named 'Scripting Utilities' into the 'Plug-Ins' folder (C:\Program Files\Adobe\Adobe   Photoshop CS6 (64 Bit)\Plug-ins\)
      2. created a new folder named 'Automate' within this same 'Plug-Ins' folder
      3. placed the file named 'ScriptListener.8li' into the 'ScriptingUtilities' folder.
      Now my scripts run fine, but when I try to create a new script, I used to just double-click the file named 'ScriptingListenerJS.log' on the desktop and it would open up the script in a notepad window.
      Problem is, as stated above, the ScriptingListenerJS.log file is no longer on the desktop.
      Would anyone know how to get that back?
      Thanks!
        • 1. Re: Where is ScriptingListenerJS.log?
          xbytor2 Level 4
          The ScriptListener.8LI file should go straight in the Plug-Ins folder.
          If you have both 64 and 32 bit versions installed, try both plugin folders.
          • 2. Re: Where is ScriptingListenerJS.log?
            Hi, thanks-
            but how do I edit the script? In my previous setup, I was able to carry out a few processes in Photoshop (for example, select brush tool, then change layers, then choose a color from the swatches). Then, out in my desktop, I would open up the file named 'ScriptingListenerJS.log' and it would open up the script into a notepad file. It was a javascript of the functions I had just performed in Photoshop (select brush, change layers, select a color). So with the script still open in notepad, I would save it as 'my_script.jsx' and every time I ran this .jsx file from now on, it would carry out the above actions automatically in Photoshop. Sorry if I wasn't making sense.
            I have found the 'ScriptListener.8li' in the Plug-ins\ScriptingUtilities folder, but don't know what to do with it - I can't edit it in notepad and save it as a .jsx script file.
            • 3. Re: Where is ScriptingListenerJS.log?
              Michael L Hale Level 5
              Photoshop saves the scriptlistener logs to the desktop on both WindowsXP and Windows7. If you are not seeing the log on the desktop after your upgrade it is because the plugin is not installed. To install you copy 'ScriptListener.8li' from the utilities folder to the plugin folder. If you want the plugin to record in both the 32 and 64 bit versions you need to copy it to each folder. That is to say if it is in the 32bit plugin folder only nothing gets recorded in the 64bit version.
              You don't edit the plugin itself. You edit the log. The log is named 'ScriptingListenerJS.log' for the javascript version.
              • 4. Re: Where is ScriptingListenerJS.log?
                Thanks Michael. This worked.
                • 5. Re: Where is ScriptingListenerJS.log?
                  You can sort of add controls to stop and start recording by changing the attributes of the scriptlistener log files.  I don't use VBS so I just make the ScriptingListenerVB.log file read only, hidden and system.  To keep it out of site mind and empty, I control the javascript log with a BAT file. I have created a shortcut for it when user it opens a small dos window for controlling the log.
                  @Echo Off
                  :loop
                            CLS
                  rem Display Log File Size
                            Dir "%USERPROFILE%\Desktop\ScriptingListenerJS.log" /T:W /4 | find "%ScriptingListenerJS.log"
                  rem Display Log Attributes  R read only Locked no R log is Unlocked
                            Attrib "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                  Rem If timeout is use the above display lines will refresh over time else you need to use enter or number
                            CHOICE /C 123456 /N /T 300 /D 6 /M "Enter:1 to Lock, 2 to Unlock, 3 to Edit, 4 to Clear, 5 To Exit :"
                            Echo %ERRORLEVEL%
                            if %ERRORLEVEL%==6 goto timeout
                            if %ERRORLEVEL%==1 goto one
                            if %ERRORLEVEL%==2 goto two
                            if %ERRORLEVEL%==3 goto three
                            if %ERRORLEVEL%==4 goto four
                            if %ERRORLEVEL%==5 goto five
                            goto loop
                  :timeout
                            goto loop
                  :one
                            Attrib +R "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                            goto loop
                  :two
                            Attrib -R "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                            goto loop
                  :three
                          Rem inline command use CMD independate command use start
                            CMD /C notepad "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                  rem          Start notepad "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                            goto loop
                  :four
                  Rem If the script log file is unlocked not read only  this echo will clear it
                            Echo. > "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                            goto loop
                  :five
                            EXIT
                  • 6. Re: Where is ScriptingListenerJS.log?
                    suzan@wardend.com
                    Michael,
                    I have Windows 10 64 bit and Photoshop CS6. I cannot find the ScriptingListener.plugin for CS6 at Photoshop CC add-ons (plug-ins and extensions) . Do you have any ideas where it might be available from an authorized source?
                    Many Thanks!!!
                    suzan
                    • 8. Re: Where is ScriptingListenerJS.log?
                      suzan@wardend.com Level 1
                      JJMack
                      Thank you so much! Just the links I needed.
                      Sincerely, Suzan Ward
