1 Reply Latest reply on Dec 22, 2007 4:26 AM by Greg Dove
    flv video problem
      hi everybody, im an actionscript 3 programmer, with some experience but im quite desperate with an issue that i can´t solve, please help help, if you know the solution to my issue my email is ideami@gmail.com, thanks so much, i explain now
      * im building an application in which i have to show many flv videos dynamically, i have tried with both systems, with the FLVPlayback component being created dynamically and with the simpler netconnection and netstream etc way, the thing itself works no probs , the videos get created no probs at all, now the problem is that videos stop playing just after they start, or they play a few times and then they freeze or sometimes they dont even load at all, this happens both locally and remotelly
      * i read about the MIME video/x-flv issue, i have apache in my computer so i set the MIME right there and i still have the problem, so it doesnt seem that the MIME issue is the problem, even more:
      * first, to provide context, i have a PC with Windows Vista, and Flash CS3 Professional, and Flash CS3 Video Converter and Riva FLV Encoder, locally i have Apache and PHP installed, remotely a fasthosts server
      * i have found that if i encode the videos without audio! they almost always work, but here comes the desperating thing, if i encode them without audio, they always load, but they still freeze sometimes.... so if videos have audio, often they dont even load, if they dont have audio, often they work perfect and play, but still after playing 2 times maybe they freeze and they dont play more
      * i have executed my application in the flash environment, in a browser locally, locally in localhost through apache, and online in a fasthosts server;
      * i thought i had found something when i realized that if i encoded the videos with no audio they seemed to play well no probs, but i have found that even then they will freeze and stop moving after a while often
      * to encode i have tried many things! the Flash CS3 video encoder with different settings, and also the RIVA FLV Encoder
      * i have also , thinking that the kind of video source could be important, i have encoded a couple of different sources with same results, i encoded uncompressed AVIs and also wmvs
      i have noticed also that sometimes videos play well in Firefox, and not in explorer, why could this be? ive heard of other people with similar problems but didnt find a solution anywhere, some tests work perfect in firefox online and not at all in Explorer, any idea?
      its all coded in actionscript 3
      thank u very much
      please anybody can help, as im quite desperate with this, thanks very much, my email is ideami@gmail.com
      all best and thank you
