1 Reply Latest reply on Dec 25, 2007 8:44 AM by Captiv8r
    Set default slide timing to .5 second
    pleasetakethisname
      Can anyone tell me how to set the default slide timing to 1 second or less? No matter what options I choose, slide timing is always determined by how long it takes me to click on the next target. Ideally, I'd like to set the slide timing to be very short, then have the timing of the objects I add determined slide length.
      Thanks for your help,
      Julie
        • 1. Re: Set default slide timing to .5 second
          Hi Julie and happy HannuChristmaKwanzaYule to you!
          There is only one place I'm aware of that any slide timing default may be set. In Captivate 2, you look at Project > Preferences... > Defaults tab.
          In Captivate 3, you look at Edit > Preferences... > Project node.
          In both places you will find a place to configure the default slide time. This has no effect on any existing slides and I don't believe it will factor into the mix when recording. Also it would appear the minimum limit is one second. The only places this seems to take effect are when inserting Blank slides and when creating a Blank project.
          Hopefully this helps a smidge! Rick
