1 Reply Latest reply on Nov 5, 2013 12:44 PM by Josh_Corey
    Can't get rid of black boxes when form is printed
      When I save a form to PDF there are visible black boxes around the feilds in the form. I thought these would go away once it printed but they are still there and make the form look cluttered. Any idea how to fix this?
        • 1. Re: Can't get rid of black boxes when form is printed
          Josh_Corey Adobe Employee
          There is no option in FormsCentral to modify the fields text input box borders.  You could edit the PDF in Acrobat and remove the border.  In the screen shot below I removed the border color from the top two fields, in the bottom two fields I added a fill color so you could see the input box and it doesn't just blend in with the page:
          In this screen shot the form has been filled out, and this is how it would print:
          If you are going to edit a FormsCentral PDF in Acrobat take a look at this FAQ first:  http://forums.adobe.com/docs/DOC-3661
