4 Replies Latest reply on Nov 5, 2013 3:19 PM by HeyMikey
    AutoCAD Graphics in InDesign CS6
    Andy McK
      Real quick - I made a catalog about 12 years ago in Pagemaker 6.5 which used .dxf files from AutoCAD for the illustrations. I now have InDesign CS6 and need to convert my old .P65 documents. It says that the .dxf file type is not supported. I know they're only joking, so how do I use .dxf files (or other Autodesk files) in InDesign CS6? Thanks.
        • 1. Re: AutoCAD Graphics in InDesign CS6
          Steve Werner Adobe Community Professional & MVP
          You can't use .dxf files in InDesign.
          I think I've heard there's a way of exporting AutoCAD drawings into Illustrator, but you'd have to ask in the Illustrator forum.
          • 2. Re: AutoCAD Graphics in InDesign CS6
            Rik Ramsay Level 4
            Illustrator can open .dxf and .dwg files, which you can then save as .ai for InDesign. Depending on how detailed your drawings are, you may want to keep some time aside for cleaning up the files in Illustrator - there can be a lot of extra lines that are not required.
            If not done this way already, you might also want to look into using Data Merge to compile your catalogue which could save you valuable hours.
            • 3. Re: AutoCAD Graphics in InDesign CS6
              John Mensinger Adobe Community Professional & MVP
              I gagged a little when I read this. It cannot be overstated. If I could charge by the line-removed, I'd own Adobe and Autodesk by now.
              • 4. Re: AutoCAD Graphics in InDesign CS6
                HeyMikey Level 3
                With you on that, John! We received a detailed map of the USA as a .dxf file with every state AND county keylined. There were some counties which literally had over 100 identical half-point rules (in rich black, no less!) on top of one another. It was like an endless world of layers in Illustrator. It took Illustrator over 5 minutes to open and then the scary beachball for another 5 minutes while it redrew. Our solution was to immediately switch to wireframe mode to be able to work with removing the excess lines. Good luck!
                Cheers!
                -Mikey
