1 Reply Latest reply on Nov 6, 2013 1:28 AM by Mylenium
    How do I make a Video with Side by side RGB + Alpha Channel?
    jashjacob
      This is how the video should should look like. I have the original video on the left.
      What i did was load the original video on after effects, switch to alpha channel and export the video in Alpha channel. Then I created a new composition imported the previous export and the original video and placed them side by side for export.
      Is this the correct way to do it ? because after the export the video on the right side lost it's transperancy.
      Is there any alternatives that I could load the video as two layers and add some effect that could get the me the same output ?
        • 1. Re: How do I make a Video with Side by side RGB + Alpha Channel?
          It's not quite clear what you actually need and what for. An Alpha channel is just that - a greyscale representation of the transparency values, not actual transparency. In your case one would simply use the info on the right side as a matte to produce transparency. If you need something else, then simply render RGB+Alpha. I really think you have a wrong understanding of this stuff and need to figure out first what you actualyl need for the desired use case.
          Mylenium
