1 Reply Latest reply on Nov 13, 2013 8:12 PM by Sudha K
    Export PowerMath Equations to ASCII
    Sudha K
         I want to convert PowerMath equations to ASCII in indesign document.
         app.menuActions.itemByID(471686).invoke();
        When I use this code, it shows the dialog "Convert equations to PowerMath ASCII", but the process is not completed.  Don't know how to complete the process.
      How should I  click on 'Document' button to complete the process.  If anyone knows pls help me.
      Thanks in advance,
      Sudha K
        • 1. Re: Export PowerMath Equations to ASCII
          Sudha K Level 1
          I got some ideas that we can click the document button of Plug-In/Export menu dialog by using applescript.  But its not working for me. Code is,
          tell application "Adobe InDesign CS6"
              set myString to ""
              set myMainMenu to menu "Main"
              set myTypeMenu to submenu "Plug-Ins" of myMainMenu
              set myFontMenu to submenu "PowerMath" of myTypeMenu
              set myString to name of myFontMenu
              repeat with myMenuItem in menu items of myFontMenu
                  set myAssociatedMenuAction to associated menu action of myMenuItem
                  set myActionMenuName to name of myAssociatedMenuAction
                  if myActionMenuName is "Ascii Export" then
                      invoke myAssociatedMenuAction
                      activate application "Adobe InDesign CS6"
                      tell application "System Events"
                          tell process "InDesign"
                              delay 1
                              try
                                  keystroke return
                              end try
                              delay 6
                              try
                                  keystroke return
                              end try
                          end tell
                      end tell
                  end if
              end repeat
          end tell
          Whats wrong in this.  Pls help me.
