1. Re: Is there a script to create a button to set an activated frame to document size + bleed?
[Jongware] Nov 6, 2013 5:04 AM (in response to DanielHassler)Here is a script that creates a script that creates a button that sets an activated frame to document size + bleed.
Why do you need a script to create a button that sets an activated frame to document size + bleed? You might as well have a script that sets an activated frame to document size + bleed, because you already need to double-click the script that sets an activated frame to document size + bleed and so there is no need to show another button that you can click to set an activated frame to document size + bleed in that.
theScript = 'var w = new Window("dialog", "Reframe");\n'+ 'w.b = w.add("button", undefined, "Click me!");\n'+ 'w.b.onClick = function(){ w.close(3); };\n'+ 'if (w.show() == 3)\n'+ '{\n'+ 'dp = app.activeDocument.documentPreferences;\n'+ 'app.selection[0].geometricBounds = [\n'+ 'app.layoutWindows[0].activePage.bounds[0]-dp.documentBleedTopOffset,\n'+ 'app.layoutWindows[0].activePage.bounds[1]-dp.documentBleedBottomOffset,\n'+ 'app.layoutWindows[0].activePage.bounds[2]+dp.documentBleedInsideOrLeftOffset,\n'+ 'app.layoutWindows[0].activePage.bounds[3]+dp.documentBleedOutsideOrRightOffset];\n'+ '}'; writeFile = new File (app.activeScript.parent+'/new script.jsx'); writeFile = writeFile.saveDlg( 'Save script', File.fs == "Windows" ? "Script:*.jsx,All files:*.*" : function(file) { return file instanceof Folder || (!(file.hidden) && file.name.match(/\.jsx$/i)); } ); if (writeFile != null && writeFile.open("w")) { writeFile.encoding = "utf8"; writeFile.write (theScript); writeFile.close(); } -
2. Re: Is there a script to create a button to set an activated frame to document size + bleed?
DanielHassler Nov 6, 2013 5:21 AM (in response to [Jongware])Hi Jongware,
thanks for your help, this is what i was looking for! Sorry for my weird description with the button, i dont have any experience with scripting in ID.
As you already said, the button is unnecessary. Nevertheless, your script works fine for me, but how can i now drop the button, so i just have to
click the script?
You are awesome, thank you so much!
3. Re: Is there a script to create a button to set an activated frame to document size + bleed?
[Jongware] Nov 6, 2013 5:32 AM (in response to DanielHassler)Yeah, that's what I figured This is the bare essentialness of what it does:
dp = app.activeDocument.documentPreferences; app.selection[0].geometricBounds = [ app.layoutWindows[0].activePage.bounds[0]-dp.documentBleedTopOffset, app.layoutWindows[0].activePage.bounds[1]-dp.documentBleedBottomOffset, app.layoutWindows[0].activePage.bounds[2]+dp.documentBleedInsideOrLeftOffset, app.layoutWindows[0].activePage.bounds[3]+dp.documentBleedOutsideOrRightOffset];
4. Re: Is there a script to create a button to set an activated frame to document size + bleed?
DanielHassler Nov 6, 2013 6:48 AM (in response to [Jongware])Awesome! For you, these are just simple commands, for me this will save me a lot of tiime every month! KCCO!
