6 Replies Latest reply: Nov 6, 2013 8:24 PM by John Daigle RSS
    Importing a Topic in RoboHelp
    Joanna Sciortino Community Member
      My question is about creating a topic and saving it on the hard drive location, and later Importing that topic to a Shared drive where the remaining topics are located.  When doing this can the Imported topic be updated in the shared drive?  Does it then save the updates to the original location (hard drive)? Or is it best to create and save the topics in it's final location?
        • 1. Re: Importing a Topic in RoboHelp
          RoboColum(n) MeganK
          Hi Joanna.
          Can I first ask why you want to do this? If you have multiple writers each working on the same files, it maybe best to implement a source control solution. Then again if you have people (e.g. subject matter experts) writing the content and you collating it, maybe using the Adobe Technical Communication Suite is the answer.
          Anyway to answer your original question....
          You can import any topic file into a RH project. It would be best if it was created in RH but it does not have to be. You can import any .HTM file. In your scenario there is no link between the local and shared version of the topic. If you import the topic from the shared location and change it in RH, it will be out of sync with your local version. You'd also need to ensure the topic was imported into your project. Simply placing it in the project directory (shared or otherwise) does not mean it is included in the project.
          One final thing. Only RH10 supports running a project on a network drive. Whilst it is possible to run a RH project on a shared drive, I would advise against it unless you have that version.
          • 2. Re: Importing a Topic in RoboHelp
            Thank you for your response.
            FYI - I am working in RH10.
            To clarify and hopefully answer your question - The shared drive is a Network drive, but only accessable by specific individuals.  There is another person that is in the same project file. When I was working from home one day and discovered the hard way that using RoboHelp from a romote location with VPN access is not very effective and I end up corrupting my file.  Was able to recover it, but have not done it since.
            So, when working from home I created a topic in RoboHelp from my own drive on the PC and once in the office I imported it into the shared drive folder.  I had noticed that when I was on the shared drive for the topic that I had imported and made a change I received a warning message.  Since then I have not created topics on my pc drive and then imported it in to the shared drive.
            • 3. Re: Importing a Topic in RoboHelp
              RoboColum(n) MeganK
              You should not get any warning message so long as RH knows about the topic file. This means using the File > Import > HTML File menu option. Using this updates the internal database so that RH knows where the file is. Once you have done this on the shared drive, you can update the topic locally and copy it back using Windows. So long as the project is closed when you do this, the update should be there when you next open it in RoboHelp.
              It may be best for you to use a source control application. This would enable you and the other user to check out a topic, thereby effectively locking anyone else from changing it, until you check your change back in.
              • 4. Re: Importing a Topic in RoboHelp
                A Source Control Application - is that built into RH10 or something else that works with RH10?  If built in where do I go to activate it?
                • 5. Re: Importing a Topic in RoboHelp
                  Captiv8r CommunityMVP
                  Hi there
                  There is no "built in" source control application. But RoboHelp does ship with a companion Source Control application you may install. It's called "RoboSource Control" and it would integrate with RoboHelp.
                  So look for the install disc or download and run it again. You should find an option to install RoboSource Control. Then you will likely need help getting started with it. That's what the link below will help with.
                  Click here
                  Cheers... Rick
                  • 6. Re: Importing a Topic in RoboHelp
                    John Daigle CommunityMVP
                    Just to chime in with what Rick mentioned. There's a really good link here that summarizes everything you need including a download link.
                    http://blogs.adobe.com/techcomm/2012/10/installing-configuring-and-using-robosource-contro l-in-a-multiuser-environment.html
                    John Daigle
                    Adobe Certified RoboHelp and Captivate Instructor
                    Evergreen, Colorado
                    www.showmethedemo.com
