2 Replies Latest reply on Nov 7, 2013 1:09 AM by beh_gras_beh
    JPG resolution and quality
    beh_gras_beh Level 1
      Dear Indesign scripters,
      I'm having a very old script what I made for CS2 and still using for CS5.
      Now I'm having trouble to give it the option to choose the resolution in a dialog box.
      Know I'm typing the resolution manually in the script but I’m wondering if there is a way to do it with a dialog box.
      var myDoc = app.documents[0];
      app.scriptPreferences.version = "6.0"
      if(app.documents.length != 0){
           var myFolder = Folder.selectDialog ("Choose a Folder");
           if(myFolder != null){
                myExportPages(myFolder);
      else{
           alert("Please open a document and try again.");
      function myExportPages(myFolder){
           var myDocument = app.activeDocument;
           var myDocumentName = myDocument.name;
      //________________________________________________________________
      app.jpegExportPreferences.resolution = 150;
      app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.MAXIMUM;
      // JPEGOptionsQuality.LOW, JPEGOptionsQuality.MEDIUM, JPEGOptionsQuality.HIGH, JPEGOptionsQuality.MAXIMUM
      app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.exportRange;
      app.scriptPreferences.version = "7.0"
      app.jpegExportPreferences.jpegColorSpace = JpegColorSpaceEnum.RGB;
      app.activeDocument.sections.everyItem().includeSectionPrefix = false;
      p = app.activeDocument.pages.everyItem().getElements();
      for (i = 0; i < p.length; i++)
      f = File (myFolder + "/" + p[i].textFrames.item ('labelcode').contents + ".jpg");
      app.jpegExportPreferences.pageString = p[i].name;
      app.activeDocument.exportFile (ExportFormat.jpg, f );
      alert('Done!');
      Already thanks for the help.
      Greetings.
        • 1. Re: JPG resolution and quality
          Sajeev Sridharan Level 4
          Try the below code,
          If you want to create UI, Peter Kahrel documentation will be very useful for you.
          http://www.kahrel.plus.com/indesign/scriptui.html
          else{
          var w = new Window ("dialog", "Resolution Dialog");
          var e = w.add ("edittext", undefined, "type your resolution here");
          w.layout.layout();
          e.active = true;
          w.add ("button", undefined, "OK");
          w.show();
          app.jpegExportPreferences.resolution = Number(e.text);
          alert('Done!');
          Vandy
          • 2. Re: JPG resolution and quality
            That works perfectly, thank you very much!
            And thanks for the tip, i'ts rolling out of the printer as we speek!
            Greetings
