• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Timesheet entry form that auto-fills the Date ranges?
Contributor ,
Nov 06, 2013 Nov 06, 2013
I currently have a ColdFusion form & need to add a "Week Selector" drop-down above my table so that:
- when the week is chosen from the drop-down, (how do I generate these weeks drop-down values?)
- the correct dates are added to the date fields in the form.. (how do I populate the text boxes?)
- Once the user chooses the week, the Sun-Sat dates update, he then enters his time for each day..
--Choose Week-->Nov 3 thru Nov 9<-- (drop-down)
Sun---Mon---Tue---Wed---Thu---Fri---Sat (static labels)
11/03 11/04 11/05 11/06 11/07 11/08 11/09 (text boxes for dynamic dates)
0 8 8 8 8 8 (text boxes for hours entry)
Here is a sample picture of what I'm trying to roughly duplicate:
Note: This UDF post by Ben Nadel looks promising: http://www.bennadel.com/blog/719-Ask-Ben-Getting-The-Date-Based-On-The-Year-And-Week-In-ColdFusion.h...
Views
2.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor , Nov 13, 2013 Nov 13, 2013
Ok, here is my current page so far:
- Using this jq weekly calendar: http://jsfiddle.net/manishma/AVZJh/light/ I'm able to select the week and have it update my "Start thru End" dates text boxes.
- But how do I update the javascript (code below) to also "populate" the weekday column headings (highlighted in yellow) with the mm/dd?
- Lastly, I'm not sure how to do the SQL INSERT across three rows of data (highlighted in yellow)?
Here is my updated code to fill in the labels with the dates:
Votes
Translate
Translate
Contributor ,
Nov 11, 2013 Nov 11, 2013
On another note: How would I write the INSERT query that inserts the following values into the database?
- Would prefer to insert all rows with a single INSERT operation
- The INSERT should include the EmployeeID, PayrollItemCategoryID, as well as the dates/hours
- This is for CF9 w/MySQL 5.5 backend..
Votes
Translate
Translate
Report
Report
Contributor ,
(function() {
var startDate;
var endDate;
var monDate;
var tueDate;
var wedDate;
var thuDate;
var friDate;
var satDate;
var sunDate;
var selectCurrentWeek = function() {
    window
.setTimeout(function () {
('.week-picker').find('.ui-datepicker-current-day a').addClass('ui-state-active')
}, 1);
('.week-picker').datepicker( {
    showOtherMonths
: true,
    selectOtherMonths
: true,
    dateFormat
: "mm/dd",
    firstDay
: 1, // Start with Monday
    onSelect
: function(dateText, inst) {
var date = $(this).datepicker('getDate');
        startDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 1);
        endDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 7);
        monDate
        tueDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 2);
        wedDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 3);
        thuDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 4);
        friDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 5);
        satDate
= new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 6);
        sunDate
var dateFormat = inst.settings.dateFormat || $.datepicker._defaults.dateFormat;
('#startDate').val($.datepicker.formatDate( dateFormat, startDate, inst.settings ));
('#endDate').val($.datepicker.formatDate( dateFormat, endDate, inst.settings ));
('#monDate').val($.datepicker.formatDate( dateFormat, monDate, inst.settings ));
('#tueDate').val($.datepicker.formatDate( dateFormat, tueDate, inst.settings ));
('#wedDate').val($.datepicker.formatDate( dateFormat, wedDate, inst.settings ));
('#thuDate').val($.datepicker.formatDate( dateFormat, thuDate, inst.settings ));
('#friDate').val($.datepicker.formatDate( dateFormat, friDate, inst.settings ));
('#satDate').val($.datepicker.formatDate( dateFormat, satDate, inst.settings ));
('#sunDate').val($.datepicker.formatDate( dateFormat, sunDate, inst.settings ));
        selectCurrentWeek
    beforeShowDay
: function(date) {
var cssClass = '';
if(date >= startDate && date <= endDate)
            cssClass
= 'ui-datepicker-current-day';
return [true, cssClass];
    onChangeMonthYear
: function(year, month, inst) {
        selectCurrentWeek
('.week-picker .ui-datepicker-calendar tr').live('mousemove', function() { $(this).find('td a').addClass('ui-state-hover'); });
('.week-picker .ui-datepicker-calendar tr').live('mouseleave', function() { $(this).find('td a').removeClass('ui-state-hover'); });
</script>
And then in my HTML page I used:
<thead>
<tr>
<th>Type</th>
<th>Mon<br>
<input disabled id="monDate" size="5" data-mini="true"></th>
<th>Tue<br>
<input disabled id="tueDate" size="5" data-mini="true"></th>
<th>Wed<br>
<input disabled id="wedDate" size="5" data-mini="true"></th>
<th>Thu<br>
<input disabled id="thuDate" size="5" data-mini="true"></th>
<th>Fri<br>
<input disabled id="friDate" size="5" data-mini="true"></th>
<th>Sat<br>
<input disabled id="satDate" size="5" data-mini="true"></th>
<th>Sun<br>
<input disabled id="sunDate" size="5" data-mini="true"></th>
<th>Totals</th>
<th>Description</th>
</tr>
Message was edited by: jlig
Votes
Translate
Translate
Report
Report
Contributor ,
Nov 15, 2013 Nov 15, 2013
Here is the solution to populate the week-day labels:
<!--- Populate the Week Days with Dates after employee picks the week from calendar --->
$(function() {
    var startDate;
    var endDate;
    var monDate;
          var tueDate;
          var wedDate;
          var thuDate;
          var friDate;
          var satDate;
          var sunDate;
        window.setTimeout(function () {
            $('.week-picker').find('.ui-datepicker-current-day a').addClass('ui-state-active')
        }, 1);
    $('.week-picker').datepicker( {
        showOtherMonths: true,
        selectOtherMonths: true,
                    dateFormat: "mm/dd",
                    firstDay: 1, // Start with Monday
        onSelect: function(dateText, inst) {
            startDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 1);
            endDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 7);
                              monDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 1);
                              tueDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 2);
                              wedDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 3);
                              thuDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 4);
                              friDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 5);
                              satDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 6);
                              sunDate = new Date(date.getFullYear(), date.getMonth(), date.getDate() - date.getDay() + 7);
            $('#startDate').val($.datepicker.formatDate( dateFormat, startDate, inst.settings ));
            $('#endDate').val($.datepicker.formatDate( dateFormat, endDate, inst.settings ));
            $('#monDate').val($.datepicker.formatDate( dateFormat, monDate, inst.settings ));
                              $('#tueDate').val($.datepicker.formatDate( dateFormat, tueDate, inst.settings ));
                              $('#wedDate').val($.datepicker.formatDate( dateFormat, wedDate, inst.settings ));
                              $('#thuDate').val($.datepicker.formatDate( dateFormat, thuDate, inst.settings ));
                              $('#friDate').val($.datepicker.formatDate( dateFormat, friDate, inst.settings ));
                              $('#satDate').val($.datepicker.formatDate( dateFormat, satDate, inst.settings ));
                              $('#sunDate').val($.datepicker.formatDate( dateFormat, sunDate, inst.settings ));
            selectCurrentWeek();
        beforeShowDay: function(date) {
            var cssClass = '';
                cssClass = 'ui-datepicker-current-day';
        onChangeMonthYear: function(year, month, inst) {
    $('.week-picker .ui-datepicker-calendar tr').live('mousemove', function() { $(this).find('td a').addClass('ui-state-hover'); });
    $('.week-picker .ui-datepicker-calendar tr').live('mouseleave', function() { $(this).find('td a').removeClass('ui-state-hover'); });
</script>
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
Here is the solution to populate the Totals textbox..
<!--- Sum up the Regular row whenever employee modifies the time value(s) --->
<script>
    $(document).ready(function(){
        //iterate through each textboxes and add keyup
        //handler to trigger sum event
        $(".txt").each(function() {
            $(this).keyup(function(){
                calculateSum();
    function calculateSum() {
        var sum = 0;
        //iterate through each textboxes and add the values
            //add only if the value is number
            if(!isNaN(this.value) && this.value.length!=0) {
                sum += parseFloat(this.value);
        //.toFixed() method will roundoff the final sum to 2 decimal places
        $("#sum").val(sum.toFixed(2));
</script>
And the HTML on my page:
<td><input type="text" class="txt" pattern="[0-9]*" name="mon1" id="mon1" value="8" size="7" maxlength="5" data-mini="true"></td>
      <td><input type="text" class="txt" pattern="[0-9]*" name="tue1" id="tue1" value="8" size="7" maxlength="5" data-mini="true"></td>
      <td><input type="text" class="txt" pattern="[0-9]*" name="wed1" id="wed1" value="8" size="7" maxlength="5" data-mini="true"></td>
      <td><input type="text" class="txt" pattern="[0-9]*" name="thu1" id="thu1" value="" size="7" maxlength="5" data-mini="true"></td>
      <td><input type="text" class="txt" pattern="[0-9]*" name="fri1" id="fri1" value="" size="7" maxlength="5" data-mini="true"></td>
      <td><input type="text" class="txt" pattern="[0-9]*" name="sat1" id="sat1" value="" size="7" maxlength="5" data-mini="true"></td>
      <td><input type="text" class="txt" pattern="[0-9]*" name="sun1" id="sun1" value="" size="7" maxlength="5" data-mini="true"></td>
      <td id="summation"><input name="total1" type="text" class="txtT" disabled id="sum" value="" size="10" maxlength="5" data-mini="true"></td>
Votes
Translate
Translate
Report
Report
Resources
Documentation
