4 Replies Latest reply on Nov 7, 2013 5:30 AM by BEGINNER_X
    Copy and Paste in selected folder
    BEGINNER_X Level 3
      Hi All,
      I need to select(copy) ".pdf" files and paste into selected folder.
      Using Mac.
      var file = File.openDialog("Please choose PDF", "PDF:*.pdf");
      var destinationFolder = Folder.selectDialog("Select Paste Folder");
      Could anyone help on this.
      Thanks in advance
      Beginner_X
        • 1. Re: Copy and Paste in selected folder
          Sajeev Sridharan Level 4
          Try this, (tested in windows not Mac)
          var target = File(destinationFolder + "/" + file.name);
          file.copy(target);
          Vandy
          • 2. Re: Copy and Paste in selected folder
            BEGINNER_X Level 3
            Hi vandy,
            Thanks for your response. Its works like a charm...
            I tuned the above coding for copy folder and paste in the selected folder.
            But it should be fail.
            var file = Folder.selectDialog("Select Copy Folder");
            file.copy(target);
            Could you please help for the request.
            Thanks in advance
            Beginner_X
            • 3. Re: Copy and Paste in selected folder
              May be something like this, I haven't tested it
              file.copy(destinationFolder);
              Vandy
              • 4. Re: Copy and Paste in selected folder
                BEGINNER_X Level 3
                Hi Vandy,
                Thanks for your response...
                Above  coding is not worked out for moving folders...
                But using forum I got below function, it works great
                function copyFolder(sourceFolder, destinationFolder) {
                    var sourceChildrenArr = sourceFolder.getFiles();
                    for (var i = 0; i < sourceChildrenArr.length; i++) {
                        var sourceChild = sourceChildrenArr[i];
                        var destinationChildStr = destinationFolder.fsName + "/" + sourceChild.name;
                        if (sourceChild instanceof File) {
                            copyFile(sourceChild, new File(destinationChildStr));
                        else {
                            copyFolder(sourceChild, new Folder(destinationChildStr));
                function copyFile(sourceFile, destinationFile) {
                    createFolder(destinationFile.parent);
                    sourceFile.copy(destinationFile);
                function createFolder(folder) {
                    if (folder.parent !== null && !folder.parent.exists) {
                        createFolder(folder.parent);
                    folder.create();
                Any other coding is also appreciatable....
                Thanks in advance
                Beginner_X
