13 Replies Latest reply on Nov 17, 2013 8:25 PM by jiawa
    Adobe Extension Manager will not install extensions
    aashhley
      The "install extensions" button is grayed out and unclickable. I have updated everything possible but it still remains the same. I am running Mac OS 10.8.5.
        • 1. Re: Adobe Extension Manager will not install extensions
          Carl Sun Level 4
          Have you installed any CS6 products such as Dreamweaver CS6 or Photoshop CS6? Apparently there is no products listed in the left panel of Extension Manager CS6. It doesn't make sense to enable "Install" button without product.
          • 2. Re: Adobe Extension Manager will not install extensions
            pimafonk
            I have the same problem since I installed Flash CC trial, all my CS6 apps disappeared from the Extension Manager CS6, and only Flash CC appears in the Extension Manager CC (that seems logic).
            I tried to uninstall the CC products using the ClearRemovalCC tool, but it doesn't change the problem.
            I'm running Mac OS 10.9 with a CS6 Master Collection.
            • 3. Re: Adobe Extension Manager will not install extensions
              aashhley Level 1
              Hi Carl,
              I have multiple Adobe CS6 products installed on my Mac. I have no idea why they aren't showing up in the panel.
              • 4. Re: Adobe Extension Manager will not install extensions
                Carl Sun Level 4
                Hi pimafonk and aashhley,
                Please run "Adobe ExtendScript Toolkit CS6" from Launch Pad or "/Applications/Utilities/Adobe Utilities-CS6/ExtendScript Toolkit CS6", input "BridgeTalk.__diagnostics__;" (exclude double quotation marks) in the main window, then click "Debug->Run". You will get diagnostics information in Javascript Console window at the top right corner.
                Please check the value of "Path" under "Targets" section to see if all CS6 products you installed have correct path. If the listed paths are not consistent with the actual install paths, Extension Manager can't list them.
                • 5. Re: Adobe Extension Manager will not install extensions
                  aashhley Level 1
                  The JavaScript Console is only displaying information for the CS5/CS4 products I have installed and shows no information for any CS6 product.
                  • 6. Re: Adobe Extension Manager will not install extensions
                    pimafonk Level 1
                    Nothing seems out of place, the path is ok.
                    This is the console log :
                    BridgeTalk Diagnostics
                              Info:
                                        Name = estoolkit-3.8
                                        Status = PUMPING
                                        Group = cs
                                        Path
                                        Version = 2.0
                                        Build = ES 4.2.12
                                        Next serial number = 40
                                        Logging: = OFF
                                        Now = 16:08:05
                                                  Message Version = 2.05
                                                  Authentication = ON
                                                  Digest = ON
                              Thread: estoolkit-3.8#thread
                                        Avg. pump interval = 52ms
                                        Last pump = 79ms ago
                                        Ping: 7
                                                  ECHO_REQUEST: ECHO_RESPONSE
                                                            Timeout = undefined
                                                            Handler = undefined
                                                  STATUS: PUMPING
                                                            Timeout = undefined
                                                            Handler = undefined
                                                  MAIN: MAIN
                                                            Timeout = undefined
                                                            Handler = installed
                                                  LAUNCHED: LAUNCHED
                                                            Timeout = undefined
                                                            Handler = installed
                                                  DIAGNOSTICS: DIAGNOSTICS
                                                            Timeout = undefined
                                                            Handler = installed
                                                  INFO: INFO
                                                            Timeout = undefined
                                                            Handler = installed
                                                  SETUPTIME: thread=1ms, left=30ms
                                                            Timeout = undefined
                                                            Handler = undefined
                              Instances: 3
                                        estoolkit-3.8#dbg:
                                                            msg[16:08:05]: 00000035
        @BT>Version = 2.05
        Target = estoolkit-3.8#dbg
        Sender = estoolkit-3.8#dbg
        Sender-ID = localhost:mac6081
        Timeout = 16:08:06
        Type = Ignore
        Response-Request = Timeout
        Headers = (no headers)
        Timestamp = 16:08:05
        Serial-Number = 35
        Received = undefined
        Result = undefined
        Error = undefined
        Body = (empty)
                                                  Incoming: 1
                                                  Outgoing: 0
                                                  Handler: 9
                                                            ExtendScript = for all messages
                                                            Error = for only msg #25
                                                            Error = for only msg #27
                                                            Error = for only msg #31
                                                            Result = for only msg #35
                                                            Error = for only msg #35
                                                            Timeout = for only msg #35
                                                            Result = for only msg #37
                                                            Error = for only msg #37
                                        estoolkit-3.8#estk:
                                                            msg[16:08:05]: 00000037
        @BT>Version = 2.05
        Target = estoolkit-3.8#estk
        Timeout = 16:18:05
        Type = Debug
        Response-Request = Result Error
        Serial-Number = 37
        Result = undefined
        Error = undefined
        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                                                  Incoming: 1
                                                  Outgoing: 0
                                                  Handler: 1
                                        estoolkit-3.8: (main)
                                                  Incoming: 0
                                                  Outgoing: 0
                                                  Handler: 1
                              Targets: 4
                                        Connector = PCD
                                        Installed: 0
                                        Running: 0
                                                  ame-7.0:
                                                            Group = cs
                                                            Path = /Applications/Adobe Media Encoder CC/Adobe Media Encoder CC.app
                                                            Display Name = Adobe Media Encoder
                                                            MsgAuthentication = ON
                                                            MsgDigest = ON
                                                            ESTK = ON
                                                            BundleID = com.adobe.ame.application
                                                            Status = (not running)
                                                            ExeName = Adobe Media Encoder CC.app
                                                  exman-6.0:
                                                            Group = cs
                                                            Path = /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app
                                                            Display Name = Adobe Extension Manager CS6
                                                            MsgDigest = ON
                                                            ESTK = OFF
                                                            BundleID = com.adobe.exman
                                                            ExeName = Adobe Extension Manager CS6.app
                                                  exman-7.0:
                                                            Group = cs
                                                            Path = /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app
                                                            Display Name = Adobe Extension Manager CC
                                                            MsgDigest = ON
                                                            ESTK = OFF
                                                            ExeName = Adobe Extension Manager CC.app
                                                  flash-13.0:
                                                            Group = cs
                                                            Path = /Applications/Adobe Flash CC/Adobe Flash CC.app
                                                            Display Name = Adobe Flash Professional CC
                                                            MsgDigest = ON
                                                            ESTK = OFF
                                                            BundleID = com.adobe.flash
                                                            ExeName = Adobe Flash CC.app
                                        Installed: 4
                                        Running: 0
                                        Groups: 139
                                                  cs3:
                                                            acrobat-8.0
                                                            aftereffects-8.0
                                                            soundbooth-1.0
                                                            bridge-2.0
                                                            contribute-4.5
                                                            devicecentral-1.0
                                                            dreamweaver-9.0
                                                            encore-3.0
                                                            estoolkit-2.0
                                                            fireworks-9.0
                                                            flash-9.0
                                                            illustrator-13.0
                                                            indesign-5.0
                                                            indesignserver-5.0
                                                            incopy-5.0
                                                            photoshop-10.0
                                                            premiere-3.0
                                                            premierepro-3.0
                                                            stockphotos-1.5
                                                            audition-3.0
                                                  cs4:
                                                            acrobat-9.0
                                                            aftereffects-9.0
                                                            soundbooth-2.0
                                                            bridge-3.0
                                                            contribute-5.0
                                                            devicecentral-2.0
                                                            dreamweaver-10.0
                                                            encore-4.0
                                                            estoolkit-3.0
                                                            fireworks-10.0
                                                            flash-10.0
                                                            illustrator-14.0
                                                            indesign-6.0
                                                            indesignserver-6.0
                                                            incopy-6.0
                                                            photoshop-11.*
                                                            premierepro-4.0
                                                            audition-4.0
                                                            ame-1.0
                                                            exman-2.0
                                                  cs5:
                                                            acrobat-9.0
                                                            aftereffects-10.0
                                                            soundbooth-3.0
                                                            bridge-4.0
                                                            contribute-6.0
                                                            devicecentral-3.0
                                                            dreamweaver-11.0
                                                            encore-5.0
                                                            estoolkit-3.5
                                                            fireworks-11.0
                                                            flash-11.0
                                                            illustrator-15.0
                                                            indesign-7.0
                                                            indesignserver-7.0
                                                            incopy-7.0
                                                            photoshop-12.*
                                                            premierepro-5.0
                                                            audition-5.0
                                                            ame-2.0
                                                            exman-3.0
                                                            flashbuilder-4.0
                                                            flashcatalyst-1.0
                                                  ts1:
                                                            captivate3-en_us
                                                            captivate3-fr_fr
                                                            captivate3-it_it
                                                            captivate3-ja_jp
                                                            captivate3-es_es
                                                            captivate3-de_de
                                                  ts2:
                                                            captivate-4.0
                                                  el2:
                                                            captivate-5.0
                                                  as1:
                                                            acrobat-10.0
                                                  ts3:
                                                            robohelp-9.0
                                                            framemaker-10.0
                                                  cs55:
                                                            aftereffects-10.5
                                                            audition-4.0
                                                            bridge-4.1
                                                            contribute-6.1
                                                            devicecentral-3.5
                                                            dreamweaver-11.5
                                                            encore-5.1
                                                            estoolkit-3.6
                                                            fireworks-11.1
                                                            flash-11.5
                                                            illustrator-15.1
                                                            indesign-7.5
                                                            indesignserver-7.5
                                                            incopy-7.5
                                                            photoshop-55.*
                                                            premierepro-5.5
                                                            ame-2.5
                                                            exman-5.5
                                                            flashbuilder-4.5
                                                            flashcatalyst-1.5
                                                            switchboard-2.0
                                                  el25:
                                                            captivate-5.5
                                                  cs60:
                                                            aftereffects-11.0
                                                            audition-5.0
                                                            bridge-5.*
                                                            contribute-6.88
                                                            devicecentral-4.0
                                                            dreamweaver-12.0
                                                            encore-6.0
                                                            estoolkit-3.8
                                                            fireworks-12.0
                                                            flash-12.0
                                                            illustrator-16.*
                                                            indesign-8.0
                                                            indesignserver-8.0
                                                            incopy-8.0
                                                            photoshop-60.*
                                                            premierepro-6.0
                                                            ame-6.0
                                                            exman-6.0
                                                            flashbuilder-4.52
                                                            switchboard-2.0
                                                            prelude-1.0
                                                            speedgrade-6.0
                                                  el60:
                                                            captivate-60.*
                                                  ts4:
                                                            robohelp-10.0
                                                            framemaker-11.0
                                                  cs70:
                                                            audition-6.0
                                                            bridge-6.*
                                                            dreamweaver-13.0
                                                            encore-7.0
                                                            fireworks-13.0
                                                            flash-13.0
                                                            illustrator-17.*
                                                            indesign-9.0
                                                            indesignserver-9.0
                                                            incopy-9.0
                                                            photoshop-70.*
                                                            premierepro-7.0
                                                            ame-7.0
                                                            exman-7.0
                                                            flashbuilder-5.0
                                                            prelude-2.0
                                                            estoolkit-4.0
                                                            aftereffects-12.0
                                                  el70:
                                                            captivate-70.*
                    • 7. Re: Adobe Extension Manager will not install extensions
                      aashhley Level 1
                      This is what mine pulled if it helps:
                      Result: BridgeTalk Diagnostics
                                Info:
                                          Status = PUMPING
                                          Path
                                          Version = 2.0
                                          Build = ES 4.2.12
                                          Next serial number = 21
                                          Logging: = OFF
                                          Now = 10:01:57
                                                    Authentication = ON
                                                    Digest = ON
                                          Avg. pump interval = 135ms
                                          Last pump = 7ms ago
                                          Ping: 7
                                                              Timeout = undefined
                                                              Handler = undefined
                                                    STATUS: PUMPING
                                                              Timeout = undefined
                                                              Handler = undefined
                                                    MAIN: MAIN
                                                              Timeout = undefined
                                                              Handler = installed
                                                    LAUNCHED: LAUNCHED
                                                              Timeout = undefined
                                                              Handler = installed
                                                              Timeout = undefined
                                                              Handler = installed
                                                    INFO: INFO
                                                              Timeout = undefined
                                                              Handler = installed
                                                    SETUPTIME: thread=0ms, left=1ms
                                                              Timeout = undefined
                                                              Handler = undefined
                                Instances: 3
                                          estoolkit-3.8#dbg:
                                                              msg[10:01:57]: 00000016
        @BT>Version = 2.05
        Sender-ID = localhost:mac7754
        Timeout = 10:01:58
        Type = Ignore
        Timestamp = 10:01:57
        Serial-Number = 16
        Result = undefined
        Error = undefined
        Body = (empty)
                                                    Incoming: 1
                                                    Outgoing: 0
                                                    Handler: 9
                                                              Error = for only msg #4
                                                              Error = for only msg #6
                                                              Error = for only msg #12
                                                              Result = for only msg #16
                                                              Error = for only msg #16
                                                              Timeout = for only msg #16
                                                              Result = for only msg #18
                                                              Error = for only msg #18
                                          estoolkit-3.8#estk:
                                                              msg[10:01:57]: 00000018
        @BT>Version = 2.05
        Timeout = 10:11:57
        Type = Debug
        Serial-Number = 18
        Result = undefined
        Error = undefined
        Body: 107 bytes
                                                    Incoming: 1
                                                    Outgoing: 0
                                                    Handler: 1
                                                    Incoming: 0
                                                    Outgoing: 0
                                                    Handler: 1
                                Targets: 6
                                          Connector = PCD
                                          Installed: 0
                                          Running: 0
                                                    bridge-4.0:
                                                              Group = cs
                                                              Path = /Applications/Adobe Bridge CS5/Adobe Bridge CS5.app
                                                              Display Name = Bridge CS5
                                                              MsgDigest = ON
                                                              ESTK = ON
                                                              BundleID = com.adobe.bridge4
                                                              ExeName = Adobe Bridge CS5.app
                                                    devicecentral-3.0:
                                                              Group = cs
                                                              Path = /Applications/Adobe Device Central CS5/Adobe Device Central CS5.app
                                                              Display Name = Adobe Device Central CS5
                                                              MsgDigest = ON
                                                              ESTK = OFF
                                                              BundleID = com.adobe.devicecentral-3.0
                                                              ExeName = Adobe Device Central CS5.app
                                                    estoolkit-3.5:
                                                              Group = cs
                                                              Path = /Applications/Utilities/Adobe Utilities-CS5.localized/ExtendScript Toolkit CS5/ExtendScript Toolkit.app
                                                              Display Name = ExtendScript Toolkit CS5
                                                              MsgDigest = ON
                                                              ESTK = ON
                                                              ExeName = ExtendScript Toolkit.app
                                                    exman-5.0:
                                                              Path = /Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app
                                                              Display Name = Adobe Extension Manager CS5
                                                              MsgDigest = ON
                                                              ESTK = OFF
                                                              ExeName = Adobe Extension Manager CS5.app
                                                    photoshop-12.032:
                                                              Group = cs
                                                              Path = /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app
                                                              Display Name = Adobe Photoshop CS5
                                                              MsgDigest = ON
                                                              ESTK = ON
                                                              BundleID = com.adobe.Photoshop
                                                              ExeName = Adobe Photoshop CS5.app
                                                    switchboard-2.0:
                                                              Path = /Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app
                                                              Display Name = SwitchBoard 2.0
                                                              MsgDigest = ON
                                                              ESTK = OFF
                                                              ExeName = SwitchBoard.app
                                          Installed: 6
                                          Running: 0
                                          Groups: 69
                                                    cs3:
                                                              acrobat-8.0
                                                              aftereffects-8.0
                                                              soundbooth-1.0
                                                              bridge-2.0
                                                              contribute-4.5
                                                              devicecentral-1.0
                                                              dreamweaver-9.0
                                                              encore-3.0
                                                              estoolkit-2.0
                                                              fireworks-9.0
                                                              flash-9.0
                                                              illustrator-13.0
                                                              indesign-5.0
                                                              indesignserver-5.0
                                                              incopy-5.0
                                                              photoshop-10.0
                                                              premiere-3.0
                                                              stockphotos-1.5
                                                              audition-3.0
                                                    cs4:
                                                              acrobat-9.0
                                                              aftereffects-9.0
                                                              soundbooth-2.0
                                                              bridge-3.0
                                                              contribute-5.0
                                                              devicecentral-2.0
                                                              dreamweaver-10.0
                                                              encore-4.0
                                                              estoolkit-3.0
                                                              fireworks-10.0
                                                              flash-10.0
                                                              illustrator-14.0
                                                              indesign-6.0
                                                              indesignserver-6.0
                                                              incopy-6.0
                                                              photoshop-11.*
                                                              premierepro-4.0
                                                              audition-4.0
                                                              ame-1.0
                                                              exman-2.0
                                                    cs5:
                                                              acrobat-9.0
                                                              aftereffects-10.0
                                                              soundbooth-3.0
                                                              bridge-4.0
                                                              contribute-6.0
                                                              devicecentral-3.0
                                                              dreamweaver-11.0
                                                              encore-5.0
                                                              estoolkit-3.5
                                                              fireworks-11.0
                                                              flash-11.0
                                                              illustrator-15.0
                                                              indesign-7.0
                                                              indesignserver-7.0
                                                              incopy-7.0
                                                              photoshop-12.*
                                                              premierepro-5.0
                                                              audition-5.0
                                                              ame-2.0
                                                              exman-3.0
                                                              flashbuilder-4.0
                                                              flashcatalyst-1.0
                                                    ts1:
                                                              captivate3-en_us
                                                              captivate3-fr_fr
                                                              captivate3-it_it
                                                              captivate3-ja_jp
                                                              captivate3-es_es
                                                              captivate3-de_de
                                                    ts2:
                                                              captivate-4.0
                                                    el2:
                                                              captivate-5.0
                      • 8. Re: Adobe Extension Manager will not install extensions
                        Carl Sun Level 4
                        Only Flash CC is shown in the diagnostics output; no any CS6 products can be found. Extension Manager uses the same technology as ExtendScript Toolkit to find all supported products. So Extension Manager CS6 can't find products either. Something is wrong in your product configuration database. I am afraid you have to reinstall CS6 products.
                        • 9. Re: Adobe Extension Manager will not install extensions
                          Carl Sun Level 4
                          The issue is the same as pimafonk's. Extension Manager uses the same technology as ExtendScript Toolkit to find all supported products. So Extension Manager CS6 can't find products either. Something is wrong in your product configuration database. I am afraid you have to reinstall CS6 products.
                          • 10. Re: Adobe Extension Manager will not install extensions
                            aashhley Level 1
                            Unfortunately I have the subscription based creative suite and if I uninstall CS6 I will have to install CC which I cannot do because of compatability issues (specifically with InDesign) with other computers in my office. Is there a way I can redownload CS6 from the subscription based creative suite?
                            • 11. Re: Adobe Extension Manager will not install extensions
                              Carl Sun Level 4
                              Do you mean you have no CS6 installer file or DVD? There seems no CS6 products download anymore except Fireworks CS6.
                              • 12. Re: Adobe Extension Manager will not install extensions
                                aashhley Level 1
                                The subscription service does not come with a CS6 installer file or DVD. You download the individual applications from the "cloud".
                                • 13. Re: Adobe Extension Manager will not install extensions
                                  jiawa
                                  CS6 Applications can be reinstalled from https://creative.adobe.com. When you sign in on this Web Site, click "Download Center" at the top of page, then choose "InDesign",it will redirect to the page of https://creative.adobe.com/products/indesign . In  this page choose the InDesign Version "InDesignCS6", click "Download InDesign CS6" now you will download Creative Cloud Cilent, after installing and loging in, it restarts installing InDesingCS6 automatically.
