7 Replies Latest reply on Dec 10, 2013 10:57 AM by DCwebGuy
    coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
    DCwebGuy Level 1
      Why do I see all these messages in coldfusion-error.log? There are tons of them.  This is CF10/Win2008/IIS7.5.  Single server, medium site, pretty typical set up.
      Nov 07, 2013 11:10:14 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      Nov 07, 2013 11:10:37 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      Nov 07, 2013 11:11:13 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      Nov 07, 2013 11:11:17 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      Nov 07, 2013 11:11:26 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      Nov 07, 2013 11:12:31 PM org.apache.tomcat.util.http.Cookies processCookieHeader
      And so on.....
        • 1. Re: coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
          tribule Level 2
          This is a known Tomcat issue. To stop the warnings, go to \cfusion\runtime\conf\logging.properties.Set org.apache.catalina.core.ContainerBase.[Catalina].[localhost].level to WARN and then restart CF.
          • 2. Re: coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
            DCwebGuy Level 1
            Okay, good to know!  It would have been nice if this was fixed in the last round of updates.  I will make the change in logging soon.  Thank you.
            • 3. Re: coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
              DCwebGuy Level 1
              Hi, again.  I did that but I'm still getting some of those errors in my log (yes, I restarted the server).  Here are other areas of that logging.properties file, and I wonder if the other values need to be changed from INFO to WARN as well?
              # Facility specific properties.
              # Provides extra control for each logger.
              org.apache.catalina.core.ContainerBase.[Catalina].[localhost].level = WARN (this is the one I changed)
              org.apache.catalina.core.ContainerBase.[Catalina].[localhost].handlers = 2localhost.org.apache.juli.FileHandler
              org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/manager].level = INFO (what about this?)
              org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/manager].handlers = 3manager.org.apache.juli.FileHandler
              org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/host-manager].level = INFO (and this?)
              org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/host-manager].handlers = 4host-manager.org.apache.juli.FileHandler
              • 5. Re: coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
                DCwebGuy Level 1
                Hi, again.  I've changed them all, and rebooted my server several times since, and I'm still getting these annoying messages in the log.  This is in the logging.properties file under c:\coldfusion10\cfusion\runtime\conf
                org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/manager].level = WARN
                org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/host-manager].level = WARN
                But in my coldfusion-error-1.log I'm still seeing this as of today.  Is there anywhere else I should look to change the setting??
                Nov 25, 2013 11:46:25 AM org.apache.tomcat.util.http.Cookies processCookieHeader
                Nov 25, 2013 12:01:34 PM org.apache.tomcat.util.http.Cookies processCookieHeader
                Nov 25, 2013 4:42:48 PM org.apache.tomcat.util.http.Cookies processCookieHeader
                INFO: Cookies: Invalid cookie. Value not a token or quoted value
                Nov 25, 2013 4:42:53 PM org.apache.tomcat.util.http.Cookies processCookieHeader
                Nov 25, 2013 4:42:57 PM org.apache.tomcat.util.http.Cookies processCookieHeader
                Nov 25, 2013 4:43:03 PM org.apache.tomcat.util.http.Cookies processCookieHeader
                Nov 25, 2013 4:43:21 PM org.apache.tomcat.util.http.Cookies processCookieHeader
                • 6. Re: coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
                  tribule Level 2
                  I recallI that I had three logging.properties files. Edit each and also look for a section called "Default global logging level" and ensure that this has ".level= SEVERE". The logging.properties files that I have are in c:\ColdFusion10\cfusion\runtime\conf\, c:\ColdFusion10\cfusion\jetty\jre\lib and c:\ColdFusion10\cfusion\jnbridge\jre\lib. If this doesn't work for you it may be best to email Adobe install support on cfinstal@adobe.com.
                  • 7. Re: coldfusion-error.log full of "INFO: Cookies: Unknown Special Cookie"?
                    DCwebGuy Level 1
                    So I did that I think it finally helped with that specific log issue.  HOWEVER, by changing those log settings everywhere it prevented critical tiools like Jconsole and Jprofiler from running, so just FYI.
