1 Reply Latest reply on Nov 8, 2013 11:41 AM by Aegis Kleais
    deleting records
    jemz
      HI, can i ask some help,...i have some sql statement that will delete records to the database.but i am confuse on this,what if the third sql statement failed to process and then the first and second delete statement are successfully deleted the records?.how can i return the data that was deleted...
      I am using cf version 9
      <cftry>
           <cfquery>
            // delete statement here
         </cfquery>
        <cfquery>
         </cfquery>
          <cfquery>
         </cfquery>
           <cfcatch type='Any'>
          <cfset log_error='#CFCATCH.Detail# #CFCATCH.Message#'>
           <cfquery name="automatedtask" datasource="#mysource#">
            //   INSERT statemnent here
           </cfquery>
         </cfcatch>
       </cftry>
        • 1. Re: deleting records
          Aegis Kleais Level 3
          If the 3 statements need to happen together or not (when 1 or more fail), and your database supports transactions, you should use <cftransaction>
          The short of it is:
          <cftransaction action="begin">
               <cftry>
                    <cfquery name="test1" datasource="dsn">
                         select * from blah
                    </cfquery>
                         select * from blah
                    </cfquery>
                         select * from blah
                    </cfquery>
                    <cfcatch>
                         <cftransaction action="rollback" />
                    </cfcatch>
               </cftry>
               <cftransaction action="commit" />
          </cftransaction>
