2 Replies Latest reply on Nov 9, 2013 11:58 AM by Venture1
    Crop tool graphical bug on Retina MBP
    Venture1
      I just discovered another bug! This time it affects the Crop tool, and I've only noticed this on my Retina MacBook Pro so far. Here's what it is:
      I opened a 16 bit image. When using the crop tool in default mode (NOT classic) when the entire canvas is visible (so not zoomed in), I switched to the crop tool, click on the canvas to get the crop rectangle, then zoomed in more and more. At some point the image goes black, with bits of image showing through, and further zooming reveals a bunch of noisy colorful pixels.
      As far as I can tell at the moment:
      This does not happen in 8 bit mode.
      I've not yet had this happen ever on any non-retina computer.
      It does not happen when you start already zoomed in somewhat.
      It does not happen when the crop tool is set to Classic mode.
      It does not happen in Windowed mode, only in Full Screen With Menu Bar mode (so press F once).
      I can reproduce it.
      Here's a video:
        • 1. Re: Crop tool graphical bug on Retina MBP
          Jeffrey Tranberry Adobe Employee
          It may help if we could see your Photoshop System Info. Directions for sharing your system info from Photoshop:
          http://feedback.photoshop.com/photoshop_family/topics/photoshop_how_do_i_share_my_system_i nformation
          • 2. Re: Crop tool graphical bug on Retina MBP
            Venture1 Level 1
            Here you go:
            Adobe Photoshop Version: 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x64
            Operating System: Mac OS 10.9.0
            System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 2300 MHz
            Built-in memory: 16384 MB
            Free memory: 10134 MB
            Memory available to Photoshop: 14903 MB
            Memory used by Photoshop: 70 %
            Image tile size: 1024K
            Image cache levels: 4
            Display: 1
            Main Display
            High DPI Monitor
            Display Bounds: top=0, left=0, bottom=900, right=1440
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            NumGPUs=1
            gpu[0].OGLVersion="2.1"
            gpu[0].MemoryMB=2048
            gpu[0].RectTextureSize=16384
            gpu[0].Renderer="NVIDIA GeForce GT 750M OpenGL Engine"
            gpu[0].RendererID=16918311
            gpu[0].Vendor="NVIDIA Corporation"
            gpu[0].VendorID=4318
            gpu[0].HasNPOTSupport=1
            gpu[0].CompileProgramGLSL=1
            gpu[0].TestFrameBuffer=1
            gpu[0].OCLSupported=1
            gpu[0].OCLVersion="1.2 (Oct  1 2013 18:21:51)"
            gpu[0].CUDASupported=0
            gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
            gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
            gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            Serial number: Tryout Version
            Application folder: /Applications/Adobe Photoshop CC/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Macintosh HD, 465.1G, 292.7G free
            Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-Ins/
            Installed components:
               adbeape.framework   adbeape   3.4.0.29366   0.1160850
               AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.30746   79.535742
               adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
               AdobeACE.framework   AdobeACE   2.20.02.31468   79.543790
               AdobeAGM.framework   AdobeAGM   4.30.24.31468   79.543790
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
               AdobeBIB.framework   AdobeBIB   1.2.03.31468   79.543790
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.543790
               AdobeCoolType.framework   AdobeCoolType   5.13.00.31468   79.543790
               AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
               AdobeExtendScript.framework   AdobeExtendScript   4.5.5.30746   79.535742
               AdobeJP2K.framework   AdobeJP2K   1.2.2.29712   79.248139
               AdobeLinguistic.framework      19061
               AdobeMPS.framework   AdobeMPS   5.8.1.30604   79.535029
               AdobeOwl.framework   AdobeOwl   5.0.13   79.533484
               AdobePDFL.framework   AdobePDFL   10.0.1.30505   79.499517
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   7.0.0.1786
               AdobeScCore.framework   AdobeScCore   4.5.5.30746   79.535742
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   79.151481   79.151481
               AdobeXMPFiles.framework   AdobeXMPFiles   79.151481   79.151481
               AdobeXMPScript.framework   AdobeXMPScript   79.151481   79.151481
               ahclient.framework   ahclient   1.8.0.31
               aif_core.framework   AdobeAIF   5.0.00   79.534508
               aif_ocl.framework   AdobeAIF   5.0.00   79.534508
               aif_ogl.framework   AdobeAIF   5.0.00   79.534508
               AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
               amtlib.framework   amtlib   7.0.0.169
               boost_date_time.framework   boost_date_time   7.0.0.0
               boost_signals.framework   boost_signals   7.0.0.0
               boost_system.framework   boost_system   7.0.0.0
               boost_threads.framework   boost_threads   7.0.0.0
               Cg.framework   NVIDIA Cg
               CIT.framework   CIT   2.1.6.30929   151865
               CITThreading.framework   CITThreading   2.1.6.30929   151865
               dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
               dvacore.framework   dvacore   7.0.0.0
               dvamarshal.framework   dvamarshal   7.0.0.0
               dvamediatypes.framework   dvamediatypes   7.0.0.0
               dvaplayer.framework   dvaplayer   7.0.0.0
               dvatransport.framework   dvatransport   7.0.0.0
               dvaunittesting.framework   dvaunittesting   7.0.0.0
               dynamiclink.framework   dynamiclink   7.0.0.0
               FileInfo.framework   FileInfo   79.151561   79.151561
               filter_graph.framework   AdobeAIF   5.0.00   79.534508
               ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
               ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
               LogSession.framework   LogSession   2.1.2.1785
               mediacoreif.framework   mediacoreif   7.0.0.0
               patchmatch.framework   patchmatch   1.2.00.31297   79.542390
               PlugPlugOwl.framework   PlugPlugOwl   4.0.1.34
               UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
               WRServices.framework
            Required plug-ins:
               3D Studio 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Accented Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 8.2 (94), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 8.2 (94), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 14.1.2 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 14.1.2 x001  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dicom 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “dicom.plugin”
               Difference Clouds 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 14.1.2 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Embed Watermark NO VERSION - from the file “DigiSign.plugin”
               Entropy 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Extrude 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 14.1.2 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Flash 3D 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Fresco 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Graphic Pen 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               IFF Format 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Ink Outlines 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 14.1.2 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Kurtosis 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Lens Blur 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 14.0, Copyright © 2001-2013 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Maximum 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mean 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Measurement Core 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Median 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mezzotint 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Minimum 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               MMXCore Routines 14.1.2 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 14.1.2 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Oil Paint 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
               OpenEXR 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Photoshop Touch CC (14.0.0.0) ©1993-2013 Adobe Systems Incorporated - from the file “PSDX.plugin”
               Picture Package Filter 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PNG 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Radial Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 14.1.2 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Range 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Read Watermark NO VERSION - from the file “DigiRead.plugin”
               Reticulation 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 14.0, Copyright © 1999-2013 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shake Reduction 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
               Shear 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Skewness 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Smart Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spatter 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Standard Deviation 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               STL 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Sumi-e 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Summation 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Targa 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Underpainting 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Variance 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Water Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Wind 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins: NONE
            Plug-ins that failed to load: NONE
            Flash: NONE
            Installed TWAIN devices: NONE
