Hello!
I am using Cp 6, and when I play back my recording clips, the sound it barely audible because it's so soft (i.e. it sounds like it's way off in the distance). Even though I am NOT speaking softly. Can anyone help me with this issue please? Thanks!
Did you test your recording levels to ensure correct volume before recording?
What gain setting were you using? (This depends very much on the microphone you are using. Some might be fine at 1, others may need to be set to 2 or 3)
Actually, when I went back in to "edit audio" for each slide, the "adjust volume" feature appears, which allows you to raise the volume on each slide. THANKS!
