2 Replies Latest reply on Nov 11, 2013 5:48 AM by Peter Spier
    Swedish dictionary
    najje117 Level 1
      I have tried to change the language in the dictionary section, and i have activated dynamic spell checking.
      But it doesnt work with the swedish language, it only spell checks english
      i have installed the latest indesign cc
        • 1. Re: Swedish dictionary
          Salah Fadlabi Level 5
          Try to change language in control panel or character panel.
          • 2. Re: Swedish dictionary
            To expand on waht Salah is saying, the Dictionary settings in the application preferences are only there to allow you to choose which dictionary you will use when more than one is installed for a particular language. The language assigned to the text, and which will be used during spellcheck and for hyphenation, is assigned at the character level. This allows you to set a default language for text in your document, then to select individual words and assign a different language so that you can mix languages within the text, and each should spellceck and hyphenate corredtly according to the rules of that language.
