5 Replies Latest reply on Nov 11, 2013 9:17 AM by boo radley 2013
    Changing Layer Color
    boo radley 2013 Level 3
      Hi, here's a script which changes the layer's color (the 'eye' icon) to blue:
      function setCurrentLayerBlue() {
        function cTID(s) { return app.charIDToTypeID(s); };
        function sTID(s) { return app.stringIDToTypeID(s); };
          var desc5 = new ActionDescriptor();
              var ref3 = new ActionReference();
              ref3.putEnumerated( cTID('Lyr '), cTID('Ordn'), cTID('Trgt') );
          desc5.putReference( cTID('null'), ref3 );
              var desc6 = new ActionDescriptor();
              desc6.putEnumerated( cTID('Clr '), cTID('Clr '), cTID('Bl  ') );
          desc5.putObject( cTID('T   '), cTID('Lyr '), desc6 );
          executeAction( cTID('setd'), desc5, DialogModes.NO );
      setCurrentLayerBlue();
      and it works fine. But I can't get some of the other colors to work, such as Orange. I switched up the 'Blue' to 'Orange' and 'Blu' to "Orng' so I was hoping it would work but it isn't:
      function setCurrentLayerOrange() {
              desc6.putEnumerated( cTID('Clr '), cTID('Clr '), cTID('Orng  ') );
      setCurrentLayerOrange();
        • 1. Re: Changing Layer Color
          Chuck Uebele Adobe Community Professional & MVP
          Did you run scriptListener for each color, just to get the descriptor name?  Guessing is like trying to pick a safe combo.
          • 2. Re: Changing Layer Color
            geez I didn't even think of that.. how could I forget... I'll try it and report back..
            • 3. Re: Changing Layer Color
              worked fine... don't know why I didn't think of that in the first place..
              here's another script which used to change the layer color to a darker green than the standard green:
              function setCurrentLayerDarkGreen() {
                      desc6.putEnumerated( cTID('Clr '), cTID('Clr '), cTID('Gr  ') );
              setCurrentLayerDarkGreen();
              ..and it actually worked - it changed it to a deep green which isn't available as a standard color. But for some reason it won't work now.
              Having said that, could there be a way to change the layer colors to other colors which aren't in the menu? (Pink, brown, or any other color we can think of) ?
              • 4. Re: Changing Layer Color
                Michael L Hale Level 5
                It doesn't work for me. In fact if the layer already has a color this will set the color to none, removing the existing layer color.
                Even if it did work I wouldn't recommend tying to do something that is not supported by the GUI. I think it might cause problems to have unexpected colors in the layer descriptor.
                • 5. Re: Changing Layer Color
                  yeah it used to work - I was fascinated when I could change the color to a deep green - I always thought we were restricted to the 7 default colors (red blue yellow green violet orange gray). I don't know what went wrong though... it may have had something to do with an earlier version of Photoshop but it won't run on a more recent version. Ah well, not a big deal
